Author Topic: WISHBONE SUSPENSION ARMS SET KIT  (Read 5364 times)
MartinP
  • Dudley
    • BMW 320D
Re: WISHBONE SUSPENSION ARMS SET KIT
« Reply #15 on: 05 June 2011, 21:29:29 »
Fitted mine yesterday,
Looked exactly the same build as the wishbones I took off!
Went together OK.
Front end feels a lot better (has to as the old ones were sh**ed
« Last Edit: 05 June 2011, 21:30:07 by issunaz »
« Reply #16 on: 05 June 2011, 21:37:46 »
I used these on mine, though paid maybe £20 more 5months ago. All fitted ok, although had a spot of bother fitting  the o/s wishbone, (think my subframe is a bit wonky though). 13k later, and the front o/s bush is starting to flex. >:(
hopefully yours will last ok. Mine gets quite abusedalot of use. 1000+ hard miles a week. :-/
13k isn't too bad from a cheap set of wishbones TBH ;)
« Reply #17 on: 05 June 2011, 22:23:17 »
I guess they're service items then. ::)
It's still a good feeling driving the car once all the vagueness has been eradicated from the front end and all four wheels are pointing the same way. :y
« Reply #18 on: 05 June 2011, 22:26:41 »
I consider them a service item. Mind you, intention is to polyflex the fronts and they should then last ;)
bubbaphatass
  • Basingstoke
  • Dysfunctional Dad
« Reply #19 on: 06 June 2011, 08:01:00 »
    • E250 Est / Elroq
« Reply #20 on: 06 June 2011, 08:12:19 »
www.vauxhall-car-parts.co.uk/acatalog/Omega_Front_axle.html try this lot, genuine parts..........
Most of those arent genuine  :y
The 'N' in the part no indicates NON genuine  :y
bubbaphatass
  • Basingstoke
  • Dysfunctional Dad
« Reply #21 on: 06 June 2011, 08:17:18 »
I stand corrected lol :-X
