Author Topic: misfire and heat/stink from under car.  (Read 2010 times)
bubbaphatass
  • Basingstoke
  • Dysfunctional Dad
« on: 06 June 2011, 07:57:08 »
Was just trundling home last night, when my 1999 2.5 V6 auto/petrol began to lose power, pulled over and got out, the heat and the stink from under the car was REALLY BAD, and the engine was running really lumpy, definately not running on all cylinders, NO WARNING lights came up on the dash....any ideas? If the cats are blocked do I need the metal ones £108+vat or the ceramic type £47+vat??????? :'( :'( :'( :'( :'(
tango
  • brum
Re: misfire and heat/stink from under car.
« Reply #1 on: 06 June 2011, 11:06:31 »
when was your last cambelt changed
i got a similar experiance when my cambelt was changed lasat time but it was a touch out hence causing the misfire and the unusual hot smell
« Last Edit: 06 June 2011, 11:07:09 by tango »
« Reply #2 on: 06 June 2011, 11:37:03 »
What sort of stink?
bubbaphatass
  • Basingstoke
  • Dysfunctional Dad
« Reply #3 on: 06 June 2011, 11:38:41 »
car has only done 52k from new, so the cambelt is due a change......and the stench is of rotten eggs.
« Reply #4 on: 06 June 2011, 12:04:10 »
I would try a paperclip test http://www.omegaowners.com/forum/YaBB.pl?num=1189022687. If no fault codes are reported I would say you probably have an ignition related misfire.
If this is the case, check the plug wells for oil, the condition of the plugs and leads and, if nothing conclusive there, the coil pack.
« Reply #5 on: 06 June 2011, 12:06:23 »
Ah, over fueling. Either unburnt fuel due to misfire, or faulty injector delivering too much fuel.
do paperclip test
And then probably
Check plug wells for oil
bubbaphatass
  • Basingstoke
  • Dysfunctional Dad
« Reply #6 on: 06 June 2011, 14:57:14 »
do paperclip test
And then probably
did paperclip test.....12 12 12 then a 9?
                                                 33 exhaust voltage?
                                                 31 no rpm cos the engine wasn't running.
the plug that I took off does have a little oil in it, not much though, depends on ones definition of not much lol :D
« Reply #7 on: 06 June 2011, 15:07:35 »
You are looking for evidence of oil leaking into the area around the spark plugs, such that the top of the plug and the lead that connects to it are sitting in oil. This soon leads to the HT circuit to the spark plug being contaminated resulting in a misfire.
I'd pull all the spark plugs and check for oil, and also look at the condition of the plug itself, and the lead that feeds it.
bubbaphatass
  • Basingstoke
  • Dysfunctional Dad
« Reply #8 on: 06 June 2011, 16:05:57 »
Of the 3 plugs my limited DIY skills allow me to get to, none seem to have any ingress of oil, on the lead or plugs, I can only assume we are back to coil pack, lead or plug failure.......which as I had them ALL replaced just over a year ago....I'm not impressed at!  >:(
bubbaphatass
  • Basingstoke
  • Dysfunctional Dad
« Reply #9 on: 06 June 2011, 16:08:44 »
By the way....thank you Kevin for all your help today, hopefully Daz will sort it all next Tuesday. :D
« Reply #10 on: 06 June 2011, 16:31:08 »
Ahh.. Sounds like you're sorted then. He'll get to the bottom of it. :y
jonnycool
  • Merthyr Tydfil, S. Wales
  • We shag 'em, you eat 'em
« Reply #11 on: 06 June 2011, 18:07:39 »
The heat from under the car could be unburnt fuel travelling to the hot cats and igniting, due to the misfire. There was a member on here whose cats were glowing red hot after a motorway run because of this iirc
