Author Topic: facelift front bumper removal  (Read 1218 times)
Bionic
  • Leicester
  • Why drive anything else?
    • 1999 F/L 3.0 Elite saloon
« on: 06 June 2011, 18:16:11 »
Hm..... How do I remove the front bumper on my C facelift?
 :D
Re: facelift front bumper removal
« Reply #1 on: 06 June 2011, 19:01:28 »
Bonnet up. 2 x black "pop-up" pins......remove. Release both under headlamp trims from lights and pull out to remove. 1 torx on either wheel arch, another one under bumper corners at arch. Under front of car, 3 pins to prise out, same method as "pop-ups" under bonnet. Ease bumper off and unplug temp sensor et al. :y
Bionic
  • Leicester
« Reply #2 on: 06 June 2011, 22:10:54 »
That sounds a bit too easy cos i need to take off the whole thing including the screenwash tank and x member. Is it really just that simple? Due to some pillock pulling out of a sideroad across my path the impact put a nice big dent into the centre of the bumper and bent it back so that it now fouls the AirCon fans. I must change the steel x member too that supports the plastic part nand thought that it was screwed onto steel x member that carries the washer tank etc. ::)
« Last Edit: 06 June 2011, 22:27:44 by its.ray »
« Reply #3 on: 06 June 2011, 23:08:18 »
Once bumper is off, pull out the shock absorbing "sponge" from crossmember. Re-bar is held on with 2 nuts each end and washer bottle is bolted to re-bar. About 20 minutes and everything`s off. Can post up pics tomorrow if wanted. Have you got a replacement re-bar for the bumper?
« Last Edit: 06 June 2011, 23:09:26 by RobG »
