Author Topic: Fuel tank vent!  (Read 5474 times)
MartinP
  • Dudley
    • BMW 320D
Fuel tank vent!
« on: 06 June 2011, 23:13:01 »
needed for the kit car,
What does the omega vent look like?
Is it solonoid controlled?
Does it need power to work?
Will bring it to Newent next year for you to looksee  ;)
Help appreciated.
Thanks
Martin
Re: Fuel tank vent!
« Reply #1 on: 07 June 2011, 00:09:46 »
The system is fed vacuum from one of the two inner hose barbs on the back of the breather bridge. There's a solenoid valve on the back of the driver's side cylinder head actuated by the engine ECU.
When open, the solenoid draws fumes from the charcoal canister behind the driver's side wheel arch liner. This, in turn, collects vapours from a breather in the top of the fuel tank. The engine draws the vapours in and burns them rather than them venting to atmosphere.
The ECU periodically purges the charcoal canister when engine conditions are right to do so (light load, so plenty of vacuum, and in closed-loop mode so it can compensate for any extra fuel / air drawn in).
I doubt you need an evap. emission control system for IVA, do you? I just have an open breather on the Westfield's tank, with an anti-spill valve on it.
If using the original ECU, you'll need to have the solenoid, or a resistance to simulate it,connected to the ECU or it'll raise a fault code, You can safely block off the vacuum line if not fitting the rest of the system.
Looking forward to seeing this in the flesh.
Re: Fuel tank vent!
« Reply #2 on: 07 June 2011, 00:16:44 »
I have a feeling I may have a request incoming for the solenoid valve shortly.
Any idea what it looks like or a part number Kevin please. ;)
« Last Edit: 07 June 2011, 00:17:42 by albitz »
Re: Fuel tank vent!
« Reply #3 on: 07 June 2011, 00:20:44 »
A black cylinder-shaped valve similar to the multiram solenoid valves. It's behind the driver's side head, pretty much between the head and the HBV, IIRC.
Pipe from this valve heads off into the driver's side wheel arch.
Re: Fuel tank vent!
« Reply #4 on: 07 June 2011, 00:22:57 »
Only thing under the bonnet is the bottom end of the engine. :D ;D........might post a few pics of possible suspects tomorrow. :y
Re: Fuel tank vent!
« Reply #5 on: 07 June 2011, 08:26:01 »
Re: Fuel tank vent!
« Reply #6 on: 07 June 2011, 10:19:39 »
Rob to the rescue again. :y
Re: Fuel tank vent!
« Reply #7 on: 07 June 2011, 10:29:34 »
::) ::) ::) ::) :D :D :D :D :D
The man has an endless supply of links and photo's ;D ;D ;D ;D
Re: Fuel tank vent!
« Reply #8 on: 07 June 2011, 10:32:37 »
Not to mention sarcastic comments. :D ;D ;D ;D
Hes a good old stick really - been very helpful to me, but dont tell him I said so. ;) ::)
Re: Fuel tank vent!
« Reply #9 on: 07 June 2011, 10:36:19 »
:P :P :P
Re: Fuel tank vent!
« Reply #10 on: 07 June 2011, 10:41:57 »
Got something here which looks similar, but not quite the same.
I wonder if the later ones are a bit different.
looks like the part number is 90466244.
Also has 02v.13 (I think) and PA66 -GF30 stamped on it.
Theres a challenge for you Rob. :D ;)
Re: Fuel tank vent!
« Reply #11 on: 07 June 2011, 10:56:11 »
Mister linky to the rescue. ;D ;D ;DSorry about the pic quality. The one in my 1st pic is made by Delco-Remy. This is the GM purge valve 8-)
 ;D ;D ;D
Part # 90466244
« Last Edit: 07 June 2011, 11:00:08 by RobG »
Re: Fuel tank vent!
« Reply #12 on: 07 June 2011, 11:02:59 »
Thats the one. :y ::) ;D ;D
Same thing Kevin was talking about ?
« Last Edit: 07 June 2011, 11:04:05 by albitz »
Re: Fuel tank vent!
« Reply #13 on: 07 June 2011, 11:06:42 »
Delco-Remy fitted to earlier models, GM on later
Re: Fuel tank vent!
« Reply #14 on: 07 June 2011, 11:28:54 »
Cheers. - again. :y
