Author Topic: Help needed for heater hedgehog replacing  (Read 1714 times)
car-nut
  • Kent Border, East Sussex
  • Me & My Motors are Truly 1 off's
    • Custom Mondeo TDCi Estate
« on: 08 June 2011, 19:32:39 »
I have got the part coming tomorrow to replace my climate control hedgehog, can anyone show me a picture or give me a how to write up for replacing it please?
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
Re: Help needed for heater hedgehog replacing
« Reply #1 on: 08 June 2011, 21:38:14 »
If the hedgehog is the same on the V6 be very careful when removing old one I broke off both clips on the ducting (it was very cold when I did it) A repair headache. Have you looked at the Haynes manual for guidance Need to remove glove box to get close to the hedgehog
« Reply #2 on: 08 June 2011, 21:57:16 »
Glovebox out, then its all quite obvious.  IIRC, the vac solenoids have to come out as well?
car-nut
« Reply #3 on: 08 June 2011, 22:09:33 »
I will have a look in my haynes manual and see if it shows how to do it. But couldn't find it earlier, but will look for it again tonight.
« Reply #4 on: 08 June 2011, 22:15:37 »
Glovebox out. Look to the right and you`ll see two vac solenoids.
Remove these (2 screws each) for better access. Look right up and you can see the base of the controller held in by two clips. The clips are pushed away from the controller body to release it.
car-nut
« Reply #5 on: 08 June 2011, 22:18:40 »
Thanks
car-nut
« Reply #6 on: 08 June 2011, 22:20:17 »
As this sounds like a common fault I will try and remember to take photo's all throughout the process and try and do a write up for the maintenance section.
« Reply #7 on: 08 June 2011, 22:21:17 »
chrisdb
  • Chesterfield
« Reply #8 on: 09 June 2011, 14:39:54 »
What do these soleniod do?
TC Card, will buy parts for members near by. V6 Camshaft locking kit can rent out to members at club rates.
« Reply #9 on: 09 June 2011, 15:13:37 »
One controls the HBV (heater bypass valve) the other controls the recirculating function.
car-nut
« Reply #10 on: 09 June 2011, 18:51:47 »
Good info but me being blonde can honestly say that means GOBBLEDY GOOK to me  ;D ;D ;D
I see something, If its broke I will give it a damn good try to fix it and if not I pay a professional when I have saved up enough.  ;D ;D ;D
car-nut
« Reply #11 on: 09 June 2011, 18:52:20 »
I have got BOTH parts lol
