Author Topic: Too much pressure  (Read 1638 times)
tango
  • brum
Too much pressure
« on: 10 June 2011, 19:32:51 »
Hi all
What can be the cause of the system over pressuring
The pipes seem to feel like as if there gonna burst
mrgreen
  • Salzburg/austria
    • 2000 2.2 petrol estate
Re: Too much pressure
« Reply #1 on: 10 June 2011, 21:02:07 »
Head gasket maybe?
Warning: Dates in Calendar are closer than they appear.
joff
  • swindon, wilts
  • Discovery TD5 ES
    • Drives the wife mad
« Reply #2 on: 10 June 2011, 21:08:46 »
Had the same on an AX once ended up being a crack in the head, end EX the car went to the gods. But lets start with, have you done any work on the car of late :-?
mrgreen
  • Salzburg/austria
« Reply #3 on: 10 June 2011, 21:18:03 »
yes i say head gasket hopefully, i had a mazda with these symptoms and it wasn't the head but the block that was cracked! do you have over heating issues?
« Last Edit: 10 June 2011, 21:18:58 by mrgreen »
tango
  • brum
« Reply #4 on: 11 June 2011, 02:58:03 »
Thanks for the replies guys
I think I've solved it
I changed the 2 small electric pumps with some spares I had and seens to have done the trick
tango
  • brum
« Reply #5 on: 11 June 2011, 20:19:04 »
Ok
Thought I had this sorted but problem still there
Car doesn't overheat but once the pressure starts to build there is coolant loss throughout the jubilee type clip on the top right hand of the Rad, this will give you an example of how much pressure is being built
tango
  • brum
« Reply #6 on: 11 June 2011, 20:21:36 »
I've done loads of work to the car
Water pump thermostat and oil cooler
« Reply #7 on: 12 June 2011, 11:00:36 »
If the system is building up too much pressure the coolant expansion tank cap is designed to vent to relieve the pressure, so if it doesn't boil over out of the cap I'd say the pressure is OK. It's supposed to build a certain amount of pressure.
I'd say the problem you need to address is the leak by the radiator. Radiators are prone to the plastic cracking around the top hose union.
