Author Topic: Aircon re-gas quantities  (Read 1256 times)
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
« on: 12 June 2011, 22:23:14 »
What are the correct measurements of gas and oil required to re-charge a vacuumed system ?
Re: Aircon re-gas quantities
« Reply #1 on: 13 June 2011, 00:18:37 »
Ahh. I've seen this in TIS somewhere. Will have a look tomorrow.
900g refrigerant rings a bell. Will have to double check and also look for the figure for the PAG oil.
« Reply #2 on: 13 June 2011, 00:26:51 »
IIRC it`s 60ml oil 950g refrigerant
« Last Edit: 13 June 2011, 00:27:44 by RobG »
« Reply #3 on: 13 June 2011, 01:46:07 »
950 g refrigerant + 50 ml of oil rings a bell.
« Last Edit: 13 June 2011, 01:48:02 by dbug »
« Reply #4 on: 13 June 2011, 09:16:06 »
950 grams refrig, and 60ml PAG sounds familiar to me, but any aircon place should have the lookup charts.
If you're trying to use DIY Halfords type top-up kits, your wasting your time, as you need to give it a good vac first to boil off the remaining liquids in there.
« Reply #5 on: 13 June 2011, 09:28:27 »
filling machines test for leaks also, so worth paying imo..
« Reply #6 on: 13 June 2011, 09:31:12 »
If you are using re-fill kits, it will cost you a FORTUNE!
PAG 100 or 150 oil required.
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
« Reply #7 on: 14 June 2011, 00:26:23 »
Re-fill kits ??  :o  By jingo...No !!
Had a re-gas done at the weekend and the techie was a bit confused as his specs were telling him 900 odd, but the system only took 650.
The system is cooling fine now, but he wants to vac and re-gas it again next weekend to see if it takes the amount specified.
Page created in 0.029 seconds with 16 queries.
