Author Topic: part number  (Read 1322 times)
stuthespread
  • stevenage,herts
  • no spring chicken
part number
« on: 12 June 2011, 10:09:01 »
can anyone let me have the vx part number for ignition barrel for 2001 2.2 petrol facelift?
Re: part number
« Reply #1 on: 12 June 2011, 10:50:03 »
Have a look at this Stu, comes with 2 keys so just swap over your fobs, if this takes your fancy, ask for Steve & mention you are a member here (he is too!) & he usually gives a discount   ;)
Or you could ask one of the Breakers in the Parts for Sale section, it would probably be cheaper? ;)
The part number is the same across the range & is given in the link should you still wish to buy from a Stealer! ::) ;D :y
http://cgi.ebay.co.uk/OPEL-OMEGA-VECTRA-IGNITION-BARREL-LOCK-KEY-GM-26037948-/310324718570?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item4840cb6bea
« Last Edit: 12 June 2011, 11:10:56 by philrich1064 »
stuthespread
  • stevenage,herts
  • no spring chicken
Re: part number
« Reply #2 on: 12 June 2011, 11:11:59 »
thanks for that,i only need the barrel and keys though,there's loads on ebay but need to make sure i choose the right one.
stuthespread
  • stevenage,herts
  • no spring chicken
Re: part number
« Reply #3 on: 12 June 2011, 11:13:14 »
got part no 90140760,would that be correct?
Re: part number
« Reply #4 on: 13 June 2011, 13:05:31 »
This site appears to confirm that part number as the 'official' VX one Stu :y
http://seekpart24.com/febi/lock-cylinder-ignition-lock-2743?c=100690&at=10019
andyc
  • Norfolk
Re: part number
« Reply #5 on: 14 June 2011, 09:12:14 »
Choice of three
Unspecified Key is 90512000 @ £68.85 + VAT. This will be a different key to the rest of the car .
or you can order a specified lock to the cars orginal key number which comes out @ £41.14 + VAT.
To order this lock you will need to either go to your local dealer with your vehicle doc or give me a call if you have access to a scanner or fax
Just a note though, if the car has ever had its locls changed then the above will not work
Cheers
Andy
Thetford. Norfolk
