Author Topic: LPG question  (Read 4276 times)
LPG question
« on: 29 January 2008, 23:19:25 »
I visited "Diesellec" in Swindon today for a quote to do the new motor, they gave me this inormation :
Largest tank to go across the back  - 85 litres giving 70 litres of Gas
50 hours work - would take 7-10 working days (they would want the car for 2 weeks)
Cost - £1800
Now Elite Pete had a quote for £1100 job done in a day ( Cardiff area ?)
and the guys who did it themselves put in - I think - 100 litre tank giving 80 litres gas and reckoned it was 2 hard days work and the parts cost about £800 in total..... if memory serves me
Now this seems to me to be a major difference in many areas .. or have I got it all wrong ??? at the moment this information does not seem to tie up ... especially the work loads .. just how do you do that amount of work in one day ... properly ?
I am still very keen to gas the new beast.
« Last Edit: 29 January 2008, 23:20:45 by entwood »
Paul M
  • Edinburgh
Re: LPG question
« Reply #1 on: 29 January 2008, 23:29:07 »
Mine has a 100L tank between the wheel arches, so it's perfectly possible to fit one in the saloon. 2 weeks sounds pretty ridiculous to me too. If they only do 1 car every 2 weeks I don't rate their chances of still being in business for very long.
Re: LPG question
« Reply #2 on: 29 January 2008, 23:29:10 »
Kevin, Markie and Me did my conversion start to finish in a day and a bit.. and none of us have done LPG installs before that ;)
Re: LPG question
« Reply #3 on: 29 January 2008, 23:54:55 »
Ask them what kit they're fitting too. There's a fair difference in price between the top of the range prinz stuff and the cheaper kits. Not sure how they compare performance wise but the couple of AC kits we've fitted must have clocked up a few miles by now.
I keep meaning to work out what the options are for doughnut tanks in my saloon and get the bulk buy moving again. ::)
I would have thought with a couple of guys working on it who have done the job many times it should be easy in a couple or 3 days.
Also, make sure they're not going to be drilling manifolds in-situ or any rubbish like that. (thankfully a bit of a challenge on a V6 anyway unless they go in through the plenum top.
Taxi_Driver
Re: LPG question
« Reply #4 on: 30 January 2008, 07:05:52 »
I suspect it will be a romano.......Dieselec converted mine......i note their prices have come down.
Martin_1962
Re: LPG question
« Reply #5 on: 30 January 2008, 08:32:34 »
Mine took just over 20 hours over 4 weekends approx
Jay w
  • Plymouth/Poole
  • omega gone
Re: LPG question
« Reply #6 on: 30 January 2008, 08:52:48 »
having done one now i wouldn't hesitate in doing another.
Me, doing it on my own i would budget for 5 days;
Day one: back end, paint and install filler and filler pipework.
Day two: Injector nozzels, injectors, wiring ECU
Day three: Vapouriser and water pipes
Day four: Front to back pipes (without a ramp this can be a real pain in the a$$) interior guage and switch and finish off any jobs that havent been done or that have cropped up.
Day five: test run, set up
I have most likely overestimated here, in reality if you were really getting stuck into it 3 days would be possible, so long as everything was to go in your favour.
If you were doing it yourself i would recommend these chaps:
http://cgi.ebay.co.uk/MOTOGAS-AC-6-CYLINDER-LPG-INJECTION-GAS-CONVERSION-KIT_W0QQitemZ330206222019QQihZ014QQcategoryZ36631QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
James and i have used them, that kit he has there is just the front end kit, you will need to add a tank to that as well, i paid £705 for the whole lot, and that was with a 70 litre tank, although i wish i had gone for a larger one now, mine has done 6/7000 miles and everything is still good
I have seen a couple of people with 100l tanks, but have they got them in an Elite, don't forget you will lose a bit of space due to the bose amp in the back shelf.
If you need help there are enough people on here who have either done one or been involoved in a conversion  :y
« Last Edit: 30 January 2008, 08:54:11 by jay_w »
Re: LPG question
« Reply #7 on: 30 January 2008, 09:16:56 »
A day? This took about 45 mins  :P  :y
With two of you, you can do it in a leisurely weekend...
Re: LPG question
« Reply #8 on: 30 January 2008, 09:20:43 »
There are of course major assumptions in that statement ...............  :)
You both actually need to know what you are doing, how to do it, and have the right tools and abilities.....
Just ruled me out of the equation on 4 counts !!!!!!!!!!!!!!!!!!!!!   :)
Paul M
  • Edinburgh
Re: LPG question
« Reply #9 on: 30 January 2008, 10:26:05 »
I don't know whether this would be an issue or not, but if it is then I'm sure it can be moved easily enough. I would definitely go for the 100L tank in a saloon, as filling stations are still rather sparse in many parts of the UK, and any space left above or to the sides of the tank is pretty useless anyway.
sassanach
  • trowbridge
Re: LPG question
« Reply #10 on: 30 January 2008, 21:49:45 »
100 litre tank fits fine in a elite
Jay w
  • Plymouth/Poole
  • omega gone
Re: LPG question
« Reply #11 on: 30 January 2008, 21:57:16 »
Knowledge, there is plenty of it on here
Tools, a half decent socket set, some torx sockets, a drill, hammer, tap and die set and a hole cutter, a multimeter, soldering iron and some heat shrink, that sums it up.
the kit i bought came with the LPGA guidelines for installation, this in turn helped me with the rights and wrongs, a good wiring diagram, all i needed was the Omega wiring so i could put the two together
Re: LPG question
« Reply #12 on: 30 January 2008, 22:01:13 »
Sammy hasn't turned up yet :(
The Doctor
  • Wolverhampton
Re: LPG question
« Reply #13 on: 30 January 2008, 22:18:43 »
I can't specifically reccomend a kit, but i have chosen a different ebay kit. Alternativefuelcompany on ebay. Also sells Polish kits like the AC kit. i'm told the AFC kit is a generation or two ahead. It doesnt rely on the lambda sensor for operation, it autocalibrates by watching the injectors entirely. (exact operation i'm not sure) and another interesting feature, it is a learning ECU so recalibrates continually to account for differences in conditions and engine/gas kit wear.
I have an Estate and i want the boot, so a 60L tank is going in the spare wheel well. FULL kit including tank is £650
Re: LPG question
« Reply #14 on: 30 January 2008, 22:24:49 »
Looks interesting, and sounds like a good price. If it's anything like the AC kit it will need a bit of a tweak on the road. autocalibration on that kit really only got the idling right.
Keep us updated on how you get on with that. :y
