Author Topic: rear door removal  (Read 1266 times)
raywilb
  • york. moved to Dalton , Thirsk
    • Citroen C4 Cactus
rear door removal
« on: 16 June 2011, 16:04:19 »
does anybody on the oof know where i can get a "door hinge pin" removal tool. that will do the job. i intend trying  remove & swap  my rear doors on the mig.  never attempted the job before.
Re: rear door removal
« Reply #1 on: 16 June 2011, 16:09:52 »
Flat bladed screwdriver, failing that, a flat bladed screwdriver with a notch cut in the centre of the blade. seemples.
A little tip, disconnect multi-plug behind rubber grommet at base of pillar, undo checkstrap, then close the door before knocking pins out
MutantCav
  • Gainsborough
« Reply #2 on: 16 June 2011, 16:53:44 »
Or if (as they often are) they prove stubborn...pair of mole grips and whack them with a hammer (the mole grips, not the pins)...
To access the pins, open the front doors...you can get to them easier than access with the back doors open :y
raywilb
    • Citroen C4 Cactus
« Reply #3 on: 16 June 2011, 17:19:53 »
cheers lads, intend to try tomorrow.  :y :y
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #4 on: 16 June 2011, 19:01:58 »
Or if all else fails break out the grinder
« Reply #5 on: 16 June 2011, 19:26:29 »
You selling that mate ?  A bit of Isopon and it'll be good as new  ;D ;D ;D ;D ;D ;)
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #6 on: 16 June 2011, 19:58:44 »
Gave it to the " any old ironnnnn" man the other day, sorry mate  ;D
Stallion
  • Romford
    • 3.2 Irmscher Elite
« Reply #7 on: 17 June 2011, 01:25:23 »
Grinder it is then  :y  ;D ;D ;D
