Author Topic: Valve spring compressor  (Read 2057 times)
Tick Tock
  • Hereford
    • 2.5 V6 Facelift Estate
« on: 16 June 2011, 10:55:46 »
Hi All, I'm looking to buy a valve spring compressor to assist with the overhaul of my 2.5 V6 heads. Just had a look on ebay, and there's many different types.
Can anyone recommend a particular make that's suitable, and has the right adaptors included?
Also, whilst the valves are out, would be as well to replace the stem seals - genuine Vx parts, or aftermarket?
Omega 2.5 V6 Facelift Estate.
Martin_1962
Re: Valve spring compressor
« Reply #1 on: 16 June 2011, 18:05:28 »
Need a deep one - Sealey VS154 looks suitable
New GENUINE seals in green!
Tick Tock
  • Hereford
« Reply #2 on: 16 June 2011, 22:35:03 »
Many thanks for the advice. [purchase mode on]  :y
Matchless
  • Nottingham
    • A white van
« Reply #3 on: 17 June 2011, 13:46:53 »
Just to back-up martins comments:
The valve stem seals on e-bay used to be recommended by mark & myself but after 3 yrs / 28k I am seeing smoke on start-up and HC is rising at MoT so go for genuine stem seals.
Camshaft seals re-use or genuine...do not use pattern.
Camcover seals genuine only.
Green sealant under front cambearing caps.
Black sealant for camcover corners and D's.
I made an adaptor for my valve spring compressor out of 28mm (22mm?) copper pipe so I didnt have to buy a new long-reach one.
polilara
  • Finland
    • 2.6 Y26SE Elegance 2001
« Reply #4 on: 17 June 2011, 16:57:44 »
Hello
I see also blue smoke in start up when motor is cold. I would like to change the rubber seals, too. So do you have experience to do that job without disassembling the cylinder heads ? All other is OK, no use to disassembing - only 150 000 km driven.
Bionic
  • Leicester
  • Why drive anything else?
    • 1999 F/L 3.0 Elite saloon
« Reply #5 on: 18 June 2011, 06:00:41 »
Aftermarket??
Use them and you will soon be doing the job again.
I use a large valve compressor I got from Haflords many years ago and it does the job without prolems.
I am sure someone on here will be able to give you a model number for one they use. Try PM'ing DLK, he will advise you without any hidden agendas.
