Author Topic: Plug Leads  (Read 940 times)
mikeh
  • London
    • 1999 V6 2.5 petrol MFL
Plug Leads
« on: 20 June 2011, 10:45:32 »
Hi, can anyone recommend "ProSpark" plug leads as supplied by EuroCarParts for around £31.00 incl.
Thanks,
Mike.
mikeh
  • London
Re: Plug Leads
« Reply #1 on: 21 June 2011, 11:05:08 »
Can anyone recommend somewhere to get a set of good quality & value ignition leads.
The originals are BERU but I've read on here that even on TC the Vx ones are very expensive.
Thanks.
Re: Plug Leads
« Reply #2 on: 21 June 2011, 11:30:01 »
The originals are expensive yes.
Any other half decent make will do, depends how much you want to spend. But be aware genuine ones are all the correct length given the off centre position of the coil PAC. Generic v6 ones are all in pairs of two
lengths. So on one side you'll have a some excess to hide. Plus they also won't be numbered which makes fitting even more awkward. It's no biggy, they'll work fine, just means ,more faffing around down the back of the engine.
Decent set from a breakers maybe? There a couple on here.
mikeh
  • London
Re: Plug Leads
« Reply #3 on: 21 June 2011, 23:01:46 »
Any other half decent make will do.
I've gone for the ProSpark leads from EPS and they seem ok - well at least the misfire has gone.
