Author Topic: Lambda sensor  (Read 1125 times)
bruiser5050
  • stoke-on-trent
Lambda sensor
« on: 20 June 2011, 22:57:12 »
does anyone know how to definately diagnose a faulty Lambda without buying the new one first , Car running rich and reluctant to hold cruising speed so pretty certain its this ,
any help appreciated
Mat
Re: Lambda sensor
« Reply #1 on: 21 June 2011, 00:28:11 »
checked for codes i take it? by Pedal trick or code reader?
More than that, one of the tech2 gUys on here will no douBt.
Mr Gav
  • Leeds
    • Nissan 370z GT Edition
Re: Lambda sensor
« Reply #2 on: 22 June 2011, 18:45:53 »
Mat
WooWah test might help, try holding the revs at a steady 2k, if the revs rise and fall (hence the woowah) then it`s a sign the the lambda is goosed. Not definitive but it can point you in the right direction, also fuel economy might be slightly worse than normal.
