Author Topic: check oil level  (Read 1687 times)
tango
  • brum
check oil level
« on: 17 June 2011, 16:23:36 »
hi
keep getting this on this display
although there is enough oil in the car
is it just a case of simply changing the sensor if so where is it located
or could it be somethimg else
ie atf or engine oil not circulating properly
Re: check oil level
« Reply #1 on: 17 June 2011, 16:33:48 »
It's an engine oil level sensor in the sump so nothing to worry about if the oil level is correct per the dip stick.
Needs the sump dropped to change the sensor.
VR4Dave
  • Lincoln
Re: check oil level
« Reply #2 on: 17 June 2011, 16:47:15 »
Sump removal easy job, and worth doing, It's amazing how much crap you can clean out of there.
Re: check oil level
« Reply #3 on: 17 June 2011, 17:25:42 »
If the oil is not near max, you will see this on a cruise. Keep the oil to near max ;)
Bionic
  • Leicester
  • Why drive anything else?
    • 1999 F/L 3.0 Elite saloon
Re: check oil level
« Reply #4 on: 18 June 2011, 06:05:09 »
That started to happen on my old mig when I put an oil additive in thinking it would be a good idea.....
The oil pressure was tested and it was ok, the level was always kept at the correct mark and done while the engine was cold and level. I dropped the oil and filter and used a new filter and VX oil and the problem went! Still cant work that otu!!!!
Might work for you and is worth a try before you drop the sump. If you do you can always re-use the oil and filter again.
Hope that helps
Ray :y
« Last Edit: 18 June 2011, 06:06:07 by its.ray »
tango
  • brum
Re: check oil level
« Reply #5 on: 23 June 2011, 13:59:59 »
hi all
got some time off today so thought might uswell get my hands dirty
ive got the sump of but im having trouble with the switch is just a pull of or twist i cant work it out
tango
  • brum
Re: check oil level
« Reply #6 on: 23 June 2011, 14:01:25 »
sorry forgot to ask is it best to change the sump gasket while im at it or will it be fine
and any body giv us the torque setting when putting the sump back on thanks
