Author Topic: Exhaust Manifold Gasket Change 98 2.5V6 ELite  (Read 2215 times)
vauxsky
  • Nr Watford, Hertfordshire
    • Elite 2.5 V6 Man(S_1998)
« on: 22 June 2011, 22:06:16 »
Hi, I have looked on the forum for any info on changing the Exhaust Manifold Gasket, mine appears to be blowing on the near side - driver only. Are there any guidelines for changing these or is it common sense and streight forward.
vauxsky
Broomies Mate
  • Bristol, UK
    • Stuff!
Re: Exhaust Manifold Gasket Change 98 2.5V6 ELite
« Reply #1 on: 22 June 2011, 22:11:41 »
Not the easiest job in the world to be honest.  Biggest problem is the manifold studs shearing off.  :y
vauxsky
« Reply #2 on: 22 June 2011, 22:17:48 »
yes, thats worrying me, would heating them up help to remove them, or is that a no no because of surrounding parts. Would I have enough room to even do that.
Vauxsky
« Last Edit: 22 June 2011, 23:04:05 by dave73 »
Broomies Mate
  • Bristol, UK
    • Stuff!
« Reply #3 on: 22 June 2011, 22:21:35 »
Vauxsky
Heating them will be beneficial it will help them unwind from the block as opposed to removing the nut...... the studs are cheap from Vauxhall, so replacing them isn't an issue.
Replacement Brass nuts are a good plan (in my opinion) dont know how others feel about this though!
Tick Tock
  • Hereford
    • 2.5 V6 Facelift Estate
« Reply #4 on: 22 June 2011, 22:23:40 »
I'd agree with that, but if your manifold studs are still intact, then it's still a bugger to get at the mating surfaces to make sure they're well cleaned up before fitting new gaskets.
Always make sure you smear some copperslip on the gasket surfaces and threads before tightening everything up again.
Omega 2.5 V6 Facelift Estate.
geoffr70
  • Sunderland
  • Boobies
    • F/L 3.0 Elite, 3.0 MV6
« Reply #5 on: 22 June 2011, 22:26:49 »
TBH when i did my drivers side, all the studs came out easily. I still used all new studs and nuts which I had in anticipation.
The most awkward part i think was undoing the bolts at the rear of the coolant transfer pipe and actually getting the pipe itself out. Lots of wiggling!
TC and BnQ Trade holder.
« Reply #6 on: 23 June 2011, 08:55:26 »
Never had studs shear personaly on the V6 (unlike the 4 pots).
Access is not easiest but, its not that bad a job to do, its even been know to be completed in three hours in the middle of a field!
dad1uk
  • Birmingham
    • Vauxhall Zafira 2.2
« Reply #7 on: 23 June 2011, 11:19:23 »
This is an exception!!! ;D But then Mark is an exception!!! :y
best wishes
Simon.
paulg
  • Spalding
    • 04 3.2 manual MV6
« Reply #8 on: 23 June 2011, 19:38:59 »
Out of interest, how much are a set of steds & nuts from VX?
paulg
  • Spalding
    • 04 3.2 manual MV6
« Reply #9 on: 23 June 2011, 19:39:42 »
Studs! :-[
JasonH
« Reply #10 on: 23 June 2011, 20:54:41 »
These prices are a couple of years old but will give you an idea:
Exhaust downpipe nuts M10 x 2      90570845      approx £1.50 each (have helicoil insert)
Manifold gasket                        24416110            £5.91
Manifold nuts x 7                  11082413            £0.26 each
Manifold studs x 7                  90106924            £0.45 each
Coolant pipe O-ring                  9128362            £1.46
Front pipe gasket                  90499289            £4.55 each
Secondary Air Injection gaskets x 2            90467427            £0.40 each
paulg
  • Spalding
    • 04 3.2 manual MV6
« Reply #11 on: 23 June 2011, 22:02:45 »
Cheers for that! not as painfull as I expected! :)
« Reply #12 on: 23 June 2011, 22:05:27 »
3 hours ::)  our best time was 10 hrs for 2 ;D
although I only supply surgery tools ;D
« Last Edit: 23 June 2011, 22:09:20 by cem_devecioglu »
