Author Topic: High Mileage Miggys  (Read 2127 times)
tomoco
  • leicester
High Mileage Miggys
« on: 23 June 2011, 14:58:38 »
Do i need to change the type of oil i use in my miggy?
Mine is upto 153k now and a few so called experts have said i should use a slightly thicker oil in an engine with this sort of mileage.
I've used VX 10/40 semi for years. Changed it every 5k without fail. Its cheap enough on TC (buy 3 get one free). Just over £40 with 3 oil filters.
Is there any truth in this?
Should i change to 15/30 or something a bit thicker?
confused  :-/
« Last Edit: 23 June 2011, 14:59:21 by tomoco »
Re: High Mileage Miggys
« Reply #1 on: 23 June 2011, 15:09:00 »
continue with what your doing, 10/40 Semi every 5k is just about perfect, I change mine about every 4k.
Now on 154k, without issues  :y
Omega_Dan
« Reply #2 on: 23 June 2011, 19:09:43 »
The Vx 10w/40 will see you fine regardless of mileage :y
« Reply #3 on: 23 June 2011, 19:13:04 »
My 176k MV6 does perfectly fine on GM semi 10/40 ;)
Bionic
  • Leicester
  • Why drive anything else?
    • 1999 F/L 3.0 Elite saloon
« Reply #4 on: 24 June 2011, 07:58:13 »
Likewise as TheBoy
Just stick with genuine GM oils.
« Last Edit: 24 June 2011, 07:58:47 by its.ray »
GaryBC
  • Egham, Surrey
« Reply #5 on: 24 June 2011, 14:24:39 »
154k? Pah!! 203k - biggest job done? ABS ECU repair. Methinks I have a Wednesday car!!
tomoco
  • leicester
« Reply #6 on: 24 June 2011, 15:17:00 »
Thought as much. Gen VX is the best way :y
des.allen
  • Preston lancs
  • 2000 2.5 v6 elite nearly LPG
« Reply #7 on: 24 June 2011, 16:38:59 »
Is that all! ;D
