Author Topic: v6 heads x30xe heads onto a 3.2 y32se?  (Read 877 times)
SteveT528
« on: 24 June 2011, 18:44:08 »
Hi all, would 3.0 heads fit onto my y32se engine? im guessing their the same heads but different part numbers (3.0 heads had 4x different part numbers over the years anyway..
i have a set of new/recon 3.0 heads here that im going to port/polish which im going to run 4x g cams in. i hope they are the same if not it may rise compression from 10.1 to about 11.0 ish if they are different? would this be a bad thing if im keeping the engine N/A? Will the ecu handle a compression ratio so high?  Car is a 3.2 running 3.0 motronic 2.8 management. Any help from the tuners/guys that love modifying/playing with stuff would be great.
« Last Edit: 24 June 2011, 18:45:20 by SteveT528 »
Re: v6 heads x30xe heads onto a 3.2 y32se?
« Reply #1 on: 24 June 2011, 20:27:28 »
Yes but, make sure they are the later type with the extra webbing between the spark plugs which has the drilled and tapped hole to secure the coil packs.
SteveT528
« Reply #2 on: 24 June 2011, 21:13:18 »
Thanks Mark, im running 3.0 management with plug leads so does that mean i can use any 3.0 heads?
any idea about the compression side of things? :y
2woody
  • Northumberland
« Reply #3 on: 26 June 2011, 08:49:03 »
just measure it ?
The general rule of thumb is that any engine mods will be incompatible with the current fuel map
