Author Topic: 2.2 cutting out?  (Read 1485 times)
omegod
  • liverpool
    • 2017 Seat Ateca
2.2 cutting out?
« on: 26 June 2011, 17:43:27 »
Hi,
Whats the most likely cause of a 2.2 petrol cutting our randomly i.e. after 1 mile or 20+ miles?On my v6 I would guess crank sensor but thought these were reliable on the 2.2 engine.
Abiton
Re: 2.2 cutting out?
« Reply #1 on: 26 June 2011, 18:11:45 »
Cutting out whilst idling, or while on the go?
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #2 on: 26 June 2011, 18:14:56 »
On the go!
davethediver
  • Blackburn, Lancs.
« Reply #3 on: 26 June 2011, 18:19:03 »
Its broken :y
EDIT - Does it run rough or just cut out randomly :question
« Last Edit: 26 June 2011, 18:20:11 by davethediver »
P.A. Caron de Beaumarchais
Abiton
« Reply #4 on: 26 June 2011, 18:24:09 »
In that case crank sensor is a distinct possibility, but I think with it being a Desmond I'd want a code-read before purchasing any parts, assuming that can be done cheapish via a local member with the necessary kit.
The weakness in all the variants of Omega crank sensor seems to be the cable (insulation), which doesn't seem to get quite so hot in the standard routing on the 4-pots as on the V6s, but still gets toasty enough to turn to dust given enough time.
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #5 on: 26 June 2011, 18:26:16 »
Its broken :y
Sharp as ever Dave ;D  Just cuts out  :o , sometimes restarts straight away sometimes  a while later.
It's a mates car BTW
davethediver
  • Blackburn, Lancs.
« Reply #6 on: 26 June 2011, 18:30:30 »
Would want codes reading really Jon, Cam sensor is normally the one that goes but your symptoms aren't pointing towards that :-/
klickster
  • central scotland
    • omega 2.2 + vectra 2.2
« Reply #7 on: 27 March 2013, 23:16:13 »
For info to finish off the post.
My Omega 2.2 Auto was cutting out, ....more like losing power  coming up to roundabouts  and generally randomly losing power.
Turns out the problem  was not with the car, it was me !!
If you drive  the Automatic, and  use Left Foot  braking ... (or even  lean your foot ever so slightly on the brake pedal) you can cause the car to lose power, as it cuts  drive power when you apply the brake, which is a design safety feature.
You are supposed to drive it with one foot only, and therefor be unable to press both accelarator and brake  at the same time.
However if you drive like i was doing, then you will be causing  the problem yourself.
I now drive the Auto with one leg nailed to the floor.
It works  ...Try It ...lol
Hope this helps someone
klick   :)
Honi Soit Qui Mal Y Pense
