Author Topic: Central locking problem  (Read 1048 times)
Andy1766
  • Poole Dorset
« on: 26 June 2011, 15:40:15 »
Hi any help please, my passenger front door will not unlock/open via remote button, or any other means.
Also the boot will only open using the key other omegas I've had open via central locking.
Re: Central locking problem
« Reply #1 on: 26 June 2011, 15:51:19 »
Failed motors in both instances, unless the boot is set differently (read the manual for how to have boot open with/without central locking
Andy1766
  • Poole Dorset
« Reply #2 on: 26 June 2011, 15:52:59 »
Re the boot have followed instructions to no avail
« Reply #3 on: 26 June 2011, 15:57:04 »
Boot only opens with remote dependent on position of keyslot. Can`t remember which way, it`s either horizontal or vertical. Try it and if it doesn`t unlock in either position it`ll be the motor
« Reply #4 on: 27 June 2011, 20:45:22 »
horizontal = locks/unlocks with central locking
vertical = it doesn't  ;)
SIR Philbutt
  • Rochdale - Manchester
    • 03 2.2 CDX LPG estate
    • PJB Home Services
« Reply #5 on: 27 June 2011, 21:29:51 »
Had failed lock on one of passenger doors once. bought new motor but still no joy. Turned out to be broken cable in connection from body to door.
Check for pulse of power (fluctuation of voltmeter) on all connections in plug to motor. Each one pulses for each action Unlock, lock, dead lock, BEFORE getting a new motor as they are awkward to get out/in
Phil  :y
