Author Topic: diesel fuel injector pump is foxed  (Read 1606 times)
shadwell1981
  • leeds, west yorkshire
  • welsh man in town!!
« on: 29 June 2011, 22:33:05 »
not had car very long. 2.5 td (bmw) cdx estate. injector pump naking noise when car is reved :(. is this terminal or just expensive? is there any one that can help? this is over only car and cost is an issue! ( who dont have that problem) this is stopping a nice car being excilent!
hoofing it
Re: diesel fuel injector pump is foxed
« Reply #1 on: 29 June 2011, 22:39:39 »
The only thing that makes the pump loud is if the timing is out or the engine has been turned over by hand anti-clockwise.
Ive seen cases when the throttle body from bmw(525) was fitted to a omega and it was noisey.
If you can get the fault codes using the paperclip test post them up  :y
« Reply #2 on: 29 June 2011, 22:43:17 »
Are you sure its the pump and not the timing chains
shadwell1981
« Reply #3 on: 29 June 2011, 22:48:55 »
thanks for the quick reply, you all know your stuff. went to vx dealer ( i know!) that was the answer i got, plus 1600 quote just for pump + 3 hours labour!!! please forgive not under standing the paper clip test? is there a post telling me how and where this is done. thanks once again
shadwell1981
« Reply #5 on: 30 June 2011, 20:56:09 »
hi
just been out to the car and carried out the paper clip test, (easy when you know how). i came up with the following codes. 64 + 96. i noticed on the way home from work today, when changing down the gearbox there was a brief flash of the management light! only noticed twice as sun was shining bright.
hoofing it
« Reply #6 on: 30 June 2011, 21:09:29 »
hi
The flash of the managment light means the pump is failing. :( My own omega done the same thing then it started stalling when i took my foot off the gas whilst driving,coming to a stop at traffic lights,junctions etc.
The only fix is a new or re-con pump which will cost around £1600+fitting(brand new)
The usual fix for code 64 would be putting diesel treatment through the system but the pump is beyond this.
shadwell1981
« Reply #7 on: 30 June 2011, 21:34:46 »
thanks for the reply. well next thing i going to ask, does anyone know where i could get a diesel pump from? very cheap is the best price. dont mind traveling to collect!
hoofing it
« Reply #8 on: 30 June 2011, 21:52:07 »
Hope you have better luck than I did lol.
What to do is try any breakers to see if they have any.
replacing the pump isn't dificult so your best bet is you remove the pump from a donor car then you know how it goes back together.
If you do get a pump from a breakers get the pump re-coned before you fit it if your finances allow it :y
shadwell1981
« Reply #9 on: 30 June 2011, 22:11:16 »
now the fun of finding one  :-/ any way thanks for all your help. diesel engines are new to me. petrol in my area to tinker with. its all a learning curve! flea bay here i come.
« Reply #10 on: 30 June 2011, 23:32:56 »
I'm breaking a 2.5 diesel at the moment ;)
« Reply #11 on: 30 June 2011, 23:35:59 »
Get some diesel magic from Halfords and a new fuel filter, fill the filter with diesel magic and then fit it to the car see if that helps ;)
shadwell1981
« Reply #12 on: 01 July 2011, 22:11:43 »
even more thanks for the help. i will get some of that on my next day off and see how it goes. would you be prepaired to remove the pump on your engine as i would be happy to collect? how much you looking for?
