Author Topic: Omega 2.5 V6 1999 codes 12 and 31  (Read 1715 times)
polilara
  • Finland
    • 2.6 Y26SE Elegance 2001
« on: 03 July 2011, 10:52:18 »
Hello
These codes are from Omega of my friend. Code 31 is clear - crank sensor. Code 12 is not found, what it can be. We made paper clip test. My code reader is not with me now.
Broomies Mate
  • Bristol, UK
    • Stuff!
Re: Omega 2.5 V6 1999 codes 12 and 31
« Reply #1 on: 03 July 2011, 10:52:58 »
Code 31 is no speed signal is it not?  Engine not running.
polilara
  • Finland
« Reply #2 on: 03 July 2011, 10:55:49 »
Engine is running but sometimes stops.
« Reply #3 on: 03 July 2011, 11:15:29 »
Code 31 means that the engine was not running when you did thepaper clip test. Code 12 is the start & stop of the test.  ;) ;)
polilara
  • Finland
« Reply #4 on: 03 July 2011, 12:45:10 »
Thanks Andy B
Can we start the engine during the paper clip test ? Should the code 31 then dissappear when engine is running?
MutantCav
  • Gainsborough
« Reply #5 on: 03 July 2011, 13:07:09 »
You can indeed start the car when the paper clip is in place :y
polilara
  • Finland
« Reply #6 on: 03 July 2011, 14:25:52 »
OK MutantCav, I do my best.
« Reply #7 on: 03 July 2011, 14:52:50 »
..... Should the code 31 then dissappear when engine is running?
Yes.  ;)
