Author Topic: yet another brake light bulb  (Read 1611 times)
greenfingers 79
« on: 19 June 2011, 01:13:20 »
my 2.2dti elite keeps blowing brake light bulbs,
must have had 5 in the last year,
is there any reason for this, a common fault maybe?
im replacing them with halfords bulbs as they are fairly cheap and its local to me, its the bulb with the two elements
saltyone
  • warrington cheshire
  • my babys
    • 53 2.6cdx /06 xj6 2.7tdvi
Re: yet another brake light bulb
« Reply #1 on: 19 June 2011, 01:41:34 »
go to the stealer's and get original ones . most aftermarket bulbs are naf  :y
"friends help you move....REAL friends help you move bodies"
fiend61
  • york
  • each to their own
    • 2.5cdx 3.0mv6 3.2vec c
« Reply #2 on: 19 June 2011, 07:16:05 »
if you have had 5 halfrauds bulbs in the last year and none of them have brought up the brake light warning then you are extremely lucky  :o  usually the bulbs they use have a different resistance   >:( which causes the car not to reconise it  >:(
as above post get to the stealers they are still cheap there  :y
« Reply #3 on: 19 June 2011, 16:30:25 »
Halfords bulbs are krap - use either Vx or Ring  :y
Brikhead
  • West-Mids.
  • Sleeping. Do not disturb.
    • 2003 chitroen Saxo
« Reply #4 on: 19 June 2011, 17:36:13 »
I had to use Halfrauds the other day for a headlight bulb, just a regular H7 jobbie but they were marked up at £9.99, I got it for around three squid with a Trade Card.
Trouble was it didn't quite fit properly, I could get the old one in no problem but the new one nearly broke the fitting before I eventually managed to get it in place.
greenfingers 79
« Reply #5 on: 03 July 2011, 15:47:44 »
have changed the bulb which i got from a local car shop for 70pence and gues what two days in and its blown again, there must be a more serious problem somewhere, maybe a power surge or something
sticka_v8_init
  • Reading
    • 2.5 V6 Tourer
« Reply #6 on: 03 July 2011, 17:27:30 »
Could be arcing of the bulb in the holder. This can sometimes put voltage "spikes" through the bulb or even melt the solder on the bulb end. Check that the bulb is making proper contact.
Dodgy wiring tends to result in dim bulbs. Usually this is a bad earth.
Otherwise do the headlights go really bright as you rev the engine? If so, the alternator regulator could be playing up.
Those are my principles, if you don't like them I have others.
« Reply #7 on: 03 July 2011, 17:40:27 »
As quoted above - try genuine Vx bulb, not one from local autoshop.  Had this problem on the saloon - replaced with Ring bulb - been ok ever since  ;)
