Author Topic: hand brake cable  (Read 1082 times)
plym ian
  • Plymouth, Devon
    • 2.0 insignia elite tourer
hand brake cable
« on: 03 July 2011, 13:06:39 »
my cable has snapped is this an easy job to do and where is the best place on the web to get one> many thanks ian :)
Re: hand brake cable
« Reply #1 on: 03 July 2011, 13:52:57 »
Easy enough with heatshields removed. There`s one here, but a decent motor factors might be cheaper
http://www.ebay.co.uk/itm/Vauxhall-Opel-Omega-Handbrake-Cable-Assembly-/130520495309?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item1e63a0b4cd
plym ian
  • Plymouth, Devon
« Reply #2 on: 03 July 2011, 13:55:51 »
cheers rob will try motor factors in morning.  :)
Psychoca
  • Norfolk
    • Beaten up Mondeo TDCI ST.
« Reply #3 on: 03 July 2011, 19:44:58 »
And all the extension bars you have to hand...  I found that I could only get tiny movement on the nut...  It would be a good time to do the service on the handbrake...
« Last Edit: 03 July 2011, 19:49:54 by Psychoca »
    • 530D M Sport, 330i Coupe
« Reply #4 on: 03 July 2011, 19:49:37 »
Not sure if the 4 Pot Petrols have the heat shields over the adjuster but the DTi's don't. Just changed the cable on Jane's estate, easy enough job to do, as said above you either need a couple of ratchet extensions and a deep socket or a ratchet spanner, I had to use a normal spanner but my hand had nearly fell off after removing and refiting the adjuster bolt!
Psychoca
  • Norfolk
« Reply #5 on: 03 July 2011, 19:52:36 »
I gave up with hand tools very quickly and put my Airgun onto it... lol...
