Author Topic: powerflex buushes  (Read 2695 times)
Re: powerflex buushes
« Reply #15 on: 02 July 2011, 18:32:19 »
Fyi..
Wishbones replaced last Julyish
My geometry was done in April
1 wishbone just showing signs of play..
But I do have uneven wear (some was caused before geometry was done though)
I hope to have them by the lakes meet, but highly unlikely to have fitted them.
Just looking at the guides etc, probably a bit awkward to do on a campsite.  Shame as all new shocks / springs etc, so well setup otherwise.
Its removing the old ones.  If they come out easy (using the drilling/cutting method), its do-able. Otherwise, its going to be a pain.
Cutting the front ones out is easy enough in theory. It's just getting access under the car. A suitable chop saw type cordless tool would be handy.
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #16 on: 02 July 2011, 23:05:59 »
Shaks was nice, sharp even.  :o    :y
TBE will be fairly hopeless on it's current suspension I would think.
Jimbobs will be interesting if done in time.
I guess some sort of chop saw would be handy for cutting the bush outer to remove the standard ones.
I used my Bosch alligator saw with a metal cutting blade, works well if you're careful. :y
Shackeng
  • Ramsbury
« Reply #17 on: 02 July 2011, 23:09:28 »
I bought both the wishbone and roll bar set, they look like the ones I got, but I've only fitted the wishbones thus far. It definitely firms up the front end. ChrisG had a quick spin in it just after I fitted them. The roll bar looks like an awkward job, which I've chickened out of so far. :-[
Same here Chris ...........  >:(
On the TDs, I reckon that it's easiest if you (carefully) lower the sub-frame a touch.
However, my geometry is currently spot on, and I'm reluctant to disturb things - could make-up some locating dowels though, I suppose :-/
Thanks for that idea Byron, I'll keep that in mind. I still haven't got round to changing the AR25 to AR35 on the TD, too much work on son's house, daughter's car, and golf matches to play. I think there's a theme here, but can't quite get a hold of it. :-/ :-/ :-/ :y :y :y
« Reply #18 on: 04 July 2011, 16:12:30 »
Arrived today, good service from mjd128 on ebay  :y
