Author Topic: Oil Leak  (Read 1308 times)
Adies08
  • ipswich
    • 2000 omega cdx
Oil Leak
« on: 03 July 2011, 20:00:39 »
Hi I've just noticed that i have a small oil leak dripping off the sump plug. Anybody any idea where it could be coming from or are in the Ipswich area can help me trace it  :)
Re: Oil Leak
« Reply #1 on: 03 July 2011, 21:50:07 »
If no other areas of leak showing, you can renew the plug washer separately
Broomies Mate
  • Bristol, UK
    • Stuff!
Re: Oil Leak
« Reply #2 on: 03 July 2011, 22:01:21 »
As that is the lowest area of the engine, it could be coming from anywhere.
If no clear trace of oil from higher up then check the sump bolt.
Re: Oil Leak
« Reply #3 on: 03 July 2011, 22:08:16 »
Sump plug itself (replace o-ring/washer (depending on age))
Sump gasket (replace)
Cam cover gaskets (replace)
Oil cooler pipes (tighten)
Oil filter (investigate)
Re: Oil Leak
« Reply #4 on: 03 July 2011, 22:22:04 »
If you don't manage to track it down I'll happily have a look in a few weeks time when I'm (hopefully) back to full health ;) I couldn't even get under the car at the moment though :(
Adies08
  • ipswich
    • 2000 omega cdx
Re: Oil Leak
« Reply #5 on: 04 July 2011, 21:44:22 »
Thanks for your help guys I'll see what I can find. I might take you up on your offer when youre better lazydocker if i havent tracked it down by then
Re: Oil Leak
« Reply #6 on: 04 July 2011, 22:28:41 »
Not sure about the 2.5 but I have been told that my sump is corroded and porous, as a result I have a slight Oil leak, confirmed by the drive, but must be tiny :)
Anyway I have bought a replacement sump for fitting when next oil change is due... :y
