Author Topic: airlock  (Read 1825 times)
tooleater
  • Rickmansworth,  Herts
    • Go faster Black MV6 Man
airlock
« on: 04 July 2011, 20:52:22 »
How do I remove an Airlock from my heating system, Ive managed to to get warm air but not exactly hot at the vents,but the car still boils over,any info on airlocks would be great guys :y
Cheers John..
Re: airlock
« Reply #1 on: 04 July 2011, 20:56:17 »
Heater controls set to hot, blowers on, let engine idle with expansion tank cap removed, "burp" top hose for a few minutes
tooleater
Re: airlock
« Reply #2 on: 04 July 2011, 21:17:57 »
Thanks 4 the info Rob,but Ive tried that twice mate and  she does is get hot and the water in the expansion tank just pours out, the main hose does nt feel like theres any water in there at all..
Cheers JOHN :y
Broomies Mate
  • Bristol, UK
    • Stuff!
Re: airlock
« Reply #3 on: 04 July 2011, 21:30:47 »
Blocking in the Heater Matrix I'd hazard a guess at.
Re: airlock
« Reply #4 on: 04 July 2011, 21:32:49 »
Cheers JOHN :y
As Ross says, possible blocked matrix. Have you flushed and reverse flushed it
http://www.omegaowners.com/forum/YaBB.pl?num=1263473441
« Last Edit: 04 July 2011, 21:34:37 by RobG »
tooleater
Re: airlock
« Reply #5 on: 04 July 2011, 21:52:48 »
No Rob how do I do that Mate, and as your speaking to another member about cooling fans,this whole mess resulted from me changing the fan switch,because I was convinced that 1 or both fans should kick in on low speed around low 90s instead of 98 99deg,also I thought those 2 turbo props on the front where the cooling fans,because they certainly dont come on if I switch on Air Con :-?
John
Broomies Mate
  • Bristol, UK
    • Stuff!
Re: airlock
« Reply #6 on: 04 July 2011, 21:55:18 »
John
There is a link in his post to the 'HowTo'  :y
Is your Air-Con Working?  i.e. Very cold air at the vents?  I suppose not if the fans dont kick in.
Get an Air-Con specialist to have a look and re-gas.  :y
tooleater
Re: airlock
« Reply #7 on: 04 July 2011, 22:16:07 »
 Thanks 4 that Mate,air con is pants,but maybe I can finally get an answer to 1 of  my ?s Are the fans on  2000 face lift 30ltr suppose to come on at low speed mid temp gauge or so, b4 going 2 higher speed up in the  high 90sdeg range,if you can answer this Mate, I might get some decent kip ;D..
Cheers John. :y
Radar
  • Berkshire
    • Elite 2.5 Auto
Re: airlock
« Reply #8 on: 04 July 2011, 22:19:09 »
On mine the first fan kicks in at 95 and although i've not had the second one kick in i'd imagine it would kick in at 100?
Broomies Mate
  • Bristol, UK
    • Stuff!
Re: airlock
« Reply #9 on: 04 July 2011, 22:19:25 »
Cheers John. :y
Too many Stella's, but if I recall.... Mine will start stage 1 fan at around 93 and then kick in Stage 2 (Hurricane Mode) at 98.
Temperature gagues are notoriously wrong, so a couple of degrees either way shouldnt matter.
tooleater
Re: airlock
« Reply #10 on: 04 July 2011, 22:58:37 »
BINGO MATE,thank you so much, :y now I know that Bloody Mig has not been right since I bought her last Oct,shes not done more than 800 miles since then,but I do not feel comfortable with the fans waiting until high 90s b4 they kick in even then that look like they are on slow speed to me >:(.
I will check out that link on Flush reverse flush first Mate,will go 2 VX tomorrow and buy some Red Anti freeze,see if I can shift that Air lock and get back 2 b4,then Ill put up a post 4 info on tackling the fan problem.Once again thanks 4 all the info :y :y.GOT 2 sign off now Mate as wife wants 2 go 2 La La Land ;)
cheers John
Page created in 0.021 seconds with 14 queries.
