Author Topic: Wiper arm removal  (Read 2889 times)
Paddy Flannery
  • Hertford, Hertfordshire
    • 2003 2.6 V6
Wiper arm removal
« on: 05 July 2011, 20:13:02 »
Powersounder going off on it's own. Bonnet sensor has been disconnected for weeks no car horn and no hazards so it's the powersounder for sure, but it gave me no warnings !
Anyway ! to the point...........Following the guide I have got the retaining nut off the wiper arm, but it won't budge.
Is there anything else that I need to remove to get the wiper arm off, or is it just proving difficult to remove ?
Thanks for reading. Strange, since I started to work on the car about 20 mins ago it hasn't gone off. Silence.
Re: Wiper arm removal
« Reply #1 on: 05 July 2011, 20:14:58 »
Nothing else to come off. Try bending it on its spring, upward away from the screen and then give it a wiggle and a tug. :y
YZ250
  • Oxford/Bucks border
    • Black 3.2 Elite Estate
« Reply #2 on: 05 July 2011, 20:20:37 »
As said ^^^^^ Keep rocking it up and down and it will gradually come loose.  :y
« Reply #3 on: 05 July 2011, 20:21:57 »
There is a puller specifically for the job, be careful though of the cheap pullers. they're cheap cos they're cheaply made.  ::)
http://shop.ebay.co.uk/i.html?_from=R40&_trksid=m570.l2736&_nkw=wiper+puller
But as Albs says (and YZ250  ;)), try levering the arm by the longer bit, it will come off.  :y
« Last Edit: 05 July 2011, 20:23:02 by Andy_B »
« Reply #4 on: 05 July 2011, 20:28:15 »
The splines on the wiper shaft press into the aluminium of the arm when the nut tightens. That's all that holding it. A press fit, if you like.
To remove you need to break that fit on the shaft. Press or thump firmly down on the arm just inboard of the hinge until it wobbles a bit. Then push pull until it's loose. Hold it square to the shaft and lift it free.
Once the nut is off, no further tools are required. Just wiggle it basically.
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #5 on: 05 July 2011, 20:31:16 »
I've not had to an Omega one off yet, but every other car I've done it's been easier to bend the arm at the pivot and wiggle it loose. That way you're not fighting the spring that's designed to hold the blade against the spring.
Oh, and ensure you leave the blade on the arm whenever you're fiddling about with it; the springs are strong and the bare metal end of the arm smashing against the windscreen is NOT good. Especially on an old car with a toughened screen. You can ask me how I know that, but I'll deny everything. And the pictures are faked.
duggs
  • Felixstowe
    • BMW 3.0 Sport
« Reply #6 on: 05 July 2011, 20:32:14 »
Sure can be a bugger though....very nearly smashed the windscreen the first time I got mine off. Use a small piece of wood for a bit of leverage now.
Paddy Flannery
    • 2003 2.6 V6
« Reply #7 on: 05 July 2011, 20:59:42 »
Cheers for the help gents. Got the arm off and got access to the powersounder.
30 mins or more had elapsed and it's silent. Decided to leave it be for tonight.
From reading other posts, I was under the impression that the powersounder began making beeps after a drive to tell you the batteries were dying ........... ? However the lack of road horn sounding and lack of 4 way hazards, I supsect I may hear it again soon !
Anyway, silence for the moment. Thanks again for the prompt replies.
bigegg
  • Leeds
    • MV6 RIP - Lexus GS300 '99
« Reply #8 on: 05 July 2011, 21:41:07 »
a bit late now, but for the record:
when I removed mine, I unscrewed the nut till about half the threads showed, then gave it a sharp tap with a no.2 adjustment tool [1]
this broke the "seal" and loosened the arm enough so it came off quite easily.
make sure to leave the nut on the end to avoid damaging the thread tho.
[1] 2lb ball pein 'ammer
Carpe Incendium
« Reply #9 on: 06 July 2011, 02:45:57 »
Hopefully it won't be silently smouldering away... :-X
Bionic
  • Leicester
  • Why drive anything else?
    • 1999 F/L 3.0 Elite saloon
« Reply #10 on: 06 July 2011, 04:56:14 »
Pour boiling water over it with the nut off then a sharp pull turn and it will slide off. Do not overtighten when you put it back though.
Works every time for me...... :y
Bionic
  • Leicester
« Reply #11 on: 06 July 2011, 05:04:55 »
Don't know about why you say there is no hazards flashing or horn sounding because the poiwer sounder has nothing to do with them. All the power sounder does is to supply an emergency backup alarm with its own built in power supply in case some thief decides to disconnect the main battery.
For there to no hazards or horn sounding points to either alarm control unit behind the drivers footwell right side panel or possibly a fuse.
The alarm horn next to the power sounder unit is also known to seize and become silent but that would not affect the hazards flashing, although they do so on alarm activation only for 30 seconds.
Need more information to help any further........ ;)
« Last Edit: 06 July 2011, 05:06:10 by its.ray »
« Reply #12 on: 06 July 2011, 09:01:29 »
Unplug and remove the ps ASAP. They are known to catch fire, rarely, and yours is faulty.
hit it with a hammer
  • isle of dogs london
« Reply #13 on: 06 July 2011, 11:44:32 »
i know that feeling and as you said...i know nothing about that big long crack ::)
if it wont undo....hit it !!!!!
Paddy Flannery
    • 2003 2.6 V6
« Reply #14 on: 06 July 2011, 19:12:50 »
Locked the car last night via front and rear pass door manual method. Silent night.
Unlocked car today. Worked at front of house all day beside car. Silent.
I'm more than willing to bow to experience and I fully appreciate the fire risk, but I expected it to bleep if faulty.
Loathed to pay £60 if this was a one off, but loathed to see it burn too !
Anybody with powersounder experiences that had this one off powersounder only activation ? ( not the 4 beeps during or after a drive, the full monty activation but no hazards etc )
Will bite the bullet tomorrow by setting the alarm and staying with it.
Why do I love my Omega so much when it is one fault after another ? PITA.
