Author Topic: Autobox lever locked in Park  (Read 1380 times)
mikeh
  • London
    • 1999 V6 2.5 petrol MFL
« on: 09 July 2011, 13:16:18 »
Happened about a year ago and a new brake light switched cured the problem. This time its slightly different in that when I press the brake pedal the brake lights do come on and the check brake message disappears but there is no clicking noise from underneath the autobox selector.
Is the problem still likely to be the brake light switch or could it be the lever release solenoid?
At the moment I'm manually pressing the release lever.
Thanks,
Mike.
mantamania
  • Chatham, Kent
    • 2.6 Elite
Re: Autobox lever locked in Park
« Reply #1 on: 09 July 2011, 14:20:59 »
Hi, If you disconnect the yellow and yellow/black wires from the solenoid, either put a volt meter accross them or a 12v bulb then with the ignition on press down the brake pedal.  If either the bulb illuminates or you get a 12v reading, it points to the solenoid.
mikeh
  • London
« Reply #2 on: 09 July 2011, 14:24:59 »
mantamania, thanks for your reply. I'll give that a go.
mikeh
  • London
« Reply #3 on: 09 July 2011, 15:09:16 »
I put a voltmeter across those two wires while they were still connected. Brake pedal depressed and I get just over 11v and the solenoid worked - yellow lever went down. Is that little red thing in between the two wires a resistor? Is that what the problem is? Can I just bypass it with a paperclip?
sneakypenguin
  • Birmingham
  • Xbox gamertag MagicGinjaninja
    • 07 Volvo V70 T5
« Reply #4 on: 09 July 2011, 16:08:57 »
i had this exact same problem, mine worked intermittently then eventually gave up, I just bent the black piece of plastic around so it didn't catch and lock. Still hear the occasional click every now and then lol
07 Volvo V70 T5 SE ex police
mikeh
  • London
« Reply #5 on: 09 July 2011, 19:53:16 »
I've bent the top wire for the resistor/diode (little red thingy) so it directly touches the side casing of the solenoid and its now working fine.
Have I just bypassed the resistor or created an earth?
Thanks,
Mike.
