Author Topic: Changing Gearbox... Big Problems... HELP!!!  (Read 1899 times)
Psychoca
  • Norfolk
    • Beaten up Mondeo TDCI ST.
« on: 08 July 2011, 16:43:43 »
I am in the process of changing the gearbox on my 2.5TD Manual (R25-D), with a gearbox supplied by Brikhead which is from a 2.5 V6 (R25-28)...
When I pulled the old gearbox off and started trying to fit the slave cylinder hose, I discovered that the housings are different...
The Question is, is there any way that I can get the gearbox fitted, or is it a complete no go???
Thanks...
Re: Changing Gearbox... Big Problems... HELP!!!
« Reply #1 on: 08 July 2011, 16:50:19 »
I know on the auto you have to swap the bellhousings over since the TD engine has a different bolt pattern to the V6. Not sure if the same is true of a manual box of if it has an integral bellhousing and is thus incompatible.  :-/
Psychoca
  • Norfolk
« Reply #2 on: 08 July 2011, 17:19:31 »
Thanks Kevin....
Bugger...  The old one is well and truly knackered and certainly knackered...
I'll have a look at the housing tomorrow and see what I can do...
Omegatoy
  • UK
« Reply #3 on: 08 July 2011, 17:35:25 »
TD box is unique to TD a v6 one will not fit!!
Psychoca
  • Norfolk
« Reply #4 on: 08 July 2011, 18:06:32 »
Thanks....
2woody
  • Northumberland
« Reply #5 on: 09 July 2011, 23:48:18 »
it is possible to do but difficult
basically, you need to swap the main gearbox casing over, which is a heaty-up jobby with clearances to set via selective shims for mainshaft and countershaft eld-float.
good luck
