Author Topic: wing removal  (Read 1802 times)
Raymienets
  • Glasgow
    • 2.2 cd & 2.6 LPG
wing removal
« on: 07 July 2011, 22:05:50 »
Is there an easy solution for removing front wing i.e. fittings under sill and at headlight.
twiglet
  • Norwich, Norfolk
Re: wing removal
« Reply #1 on: 07 July 2011, 22:14:44 »
No easy solution I'm afraid matey.  :(
I had to drop the side skirt, front bumper and wheel arch liner to get the wing off for you! Took me quite a while and I finished up with a mug full of fixings!
These old buses are well screwed together!!  :y
« Last Edit: 07 July 2011, 22:15:34 by jamestayloruk »
Raymienets
  • Glasgow
    • 2.2 cd & 2.6 LPG
Re: wing removal
« Reply #2 on: 07 July 2011, 22:24:56 »
More worried about the adjusters on headlight If I have to remove it.
Re: wing removal
« Reply #3 on: 07 July 2011, 22:32:51 »
Removing the headlight wont affect the adjusters. Just dont drop it or bang it against things while its off. They dont like shock treatment. ;)
Raymienets
  • Glasgow
    • 2.2 cd & 2.6 LPG
Re: wing removal
« Reply #4 on: 07 July 2011, 23:02:37 »
That's what I mean
twiglet
  • Norwich, Norfolk
Re: wing removal
« Reply #5 on: 07 July 2011, 23:12:24 »
You don't need to remove the headlight to get the wing off mate, just the bits I listed above.  :y
I'll drop you a PM with my number and if you get stuck, give me a call. I'll try and talk you through it...  :)
How's that for service???  ;D
Raymienets
  • Glasgow
    • 2.2 cd & 2.6 LPG
Re: wing removal
« Reply #6 on: 07 July 2011, 23:46:51 »
cheers mate
Re: wing removal
« Reply #7 on: 07 July 2011, 23:52:59 »
 It can be done without taking the front bumper off but it's tight.
2 torx screws attaching the arch liner to the front bumper need to come out, then the arch liner. 3 x 10mm bolts holding the black bumper retainer then the 2 x 10mm bolts behind that. Line of bolts across the top (8 IIRC and all 10mm). Then 2 x 10mm bolts behind the sill cover, 1 x 10mm bolt at the top hinge edge from the door side and 1 x 10mm bolt about halfway up the hinge edge from inside the wheel arch :)
twiglet
  • Norwich, Norfolk
Re: wing removal
« Reply #8 on: 08 July 2011, 12:44:37 »
And be careful the bonnet doesn't eat you when you remove the gas strut that bolts through the top of the wing!  ::)
Raymienets
  • Glasgow
    • 2.2 cd & 2.6 LPG
Re: wing removal
« Reply #9 on: 08 July 2011, 23:43:31 »
cheers again will attempt during the week. Does the strip under the headlight need to be removed and if so how?
« Last Edit: 09 July 2011, 00:33:53 by Raymienets »
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
Re: wing removal
« Reply #10 on: 09 July 2011, 07:54:44 »
I had my drivers front wing off this week.
Here's a how too
Remove 4 x 10mm bolts of the top of the wing.
Remove 2 x torx screws of the bonnet strut and move it to one side.
(Watch your fingers and head if it drops)  ::)  ;D
Remove the front grill ( 2 screws / 1 clip ) to expose the screw that holds on the plastic strip that goes under the headlight. Remove the screw and plastic strip  :y
Pop off the front part of the plastic side skirt to expose 2 more 10mm bolts and remove them  :y
Remove the screw that holds the plastic liner to the corner of the front bumper and pop of the bumper corner to show 2 10mm bolts (painted), Remove them  :y
Pull back the plastic arch to expose the carbon filter.
Remove the 10mm nut that secures it and push the filter up out of the way  :y
Now If you look inside the arch at the back of the wing, Remove the insulation and you will see a 10mm bolt that screws into the back of the wing. Remove it  :y
( you can see more if you pop off the side repeater and shine a torch in there ;))
Last bolt  ;D ;D
Open the door and look at the wing and you will see a 10mm bolt screwing into the wing.
Remove it and lift the wing off  ;D ;D
Fitting is the reverse ish  ;D  but don't nip up the top bolts until you have lined the panel up  ;)
I did mine in about 20 minutes  ;D ;D
If you get problems .................. pm me your mobile number and we'll have a chat  :y
Have fun  :D :D :D
Raymienets
  • Glasgow
    • 2.2 cd & 2.6 LPG
Re: wing removal
« Reply #11 on: 10 July 2011, 12:38:47 »
Here's a how too
Last bolt  ;D ;D
Have fun  :D :D :D
Cheers Again
