Author Topic: Couple of Q's - FPR vac and gearbox drain plug  (Read 1092 times)
philhoward
  • Staffs
  • Love the engines, so put one in something else..
« on: 10 July 2011, 21:24:21 »
Hi all,
Back again after a shopping spree and have been busy fitting an X30XE into my Scimitar GTE (been done once before and a few more being done by the sounds of it) but have a few problems, mainly because I didn't remove the lump myself (it was destined for an Opel Kadett but the guy decided to go Rover V8 instead for some reason).  His loss, my gain - I ended up with an X30XE with manual gearbox from an ex-Police estate.
Gearbox drain plug - is it a common size, or do I need to visit a stealer for one?
Have managed to figure out most of the vacuum circuit aside from i'm missing one; the feed for the fuel pressure regulator.  Does it, like the multiram feeds, come off the servo feed?
I've still got to fully figure out the wiring; there might be the odd question on that if you guys don't mind?  I had a Haynes manual from when I had my Mig, but I'm blowed if I can find it!
Running an X30XE in a Reliant Scimitar GTE as I can't have an Omega as a company car...
