Author Topic: Broken bolt  (Read 1460 times)
tambrath
  • london
Broken bolt
« on: 10 July 2011, 18:22:05 »
Hi all can any one recomend a good drill bit  to remove a bolt that has sear off being trying with a hss or tit coverd one but no joy help
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
Re: Broken bolt
« Reply #1 on: 10 July 2011, 18:53:16 »
Drill a pilot hole in the bolt then use a easy out  :y
Which bolt is it ?
Re: Broken bolt
« Reply #2 on: 10 July 2011, 18:56:52 »
Cobalt drill are good, but they are best used in a pillar drill rather than a hand held drill. They're very hard so do easily snap if they snag.
eBay
tambrath
  • london
Re: Broken bolt
« Reply #3 on: 10 July 2011, 19:01:43 »
its the bolt that hols the metal pipe in place under theromastat
houseing. been try all day just keeps blunting drill bits
gstylebaby
  • stockport
Re: Broken bolt
« Reply #4 on: 10 July 2011, 19:32:33 »
Oh mate thats got to be one of the worst bolts to snap its such a t**t to get at.  Try what Andy b say cobalt drill or left handed drill bit and do as tigers said see is if you can drill it with a small bit first as a pilot hole and then get a bigger bit in there and hope it starts to come out.....Once you get it out mate mite be worth runing a tap down it if you can get at it.  Good luck mate.
Broomies Mate
  • Bristol, UK
    • Stuff!
Re: Broken bolt
« Reply #5 on: 10 July 2011, 19:43:15 »
With Steel, there is a very fine line between pressure and speed.  Ideally, moderate pressure, slow speed.
If you spin the drill at high RPM, it will kill the bit in seconds.
Either use a Battery drill or ideally an Air-Drill with a regulator on the air-line.  Adjust the regulator until the drill spins nice and slow.
It wont hurt to spray shed loads of lubricant on the point you are drilling..... do this often.
tambrath
  • london
Re: Broken bolt
« Reply #6 on: 10 July 2011, 21:43:56 »
thanks we give it a try
Bionic
  • Leicester
  • Why drive anything else?
    • 1999 F/L 3.0 Elite saloon
Re: Broken bolt
« Reply #7 on: 11 July 2011, 05:33:21 »
Oh dear!
You have learned the hard way why we all call it the B*stard bolt!  :'(
All have got it right though - all you can do is to start with a small drill and work your way up until you can get an easyout into it and then give it a good soak with Plusgas or WD and gently try it until it gives.
When you put the new one in giver it a good coat of Coppaslip!!!!!!
kcl
  • Finland
    • Volvo V60 D4 -14
Re: Broken bolt
« Reply #8 on: 11 July 2011, 06:52:13 »
Oh dear!
OP's got a TD, isn't it different, e.g. no B-bolt on it  :-/
