Author Topic: Why does Mark make it look so easy?  (Read 1315 times)
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
« on: 10 July 2011, 12:48:24 »
Need to adjust the handbrake to get it through the MOT.
Do you need to remove the heat shields on both sides?
I like red cars
    • 530D M Sport, 330i Coupe
Re: Why does Mark make it look so easy?
« Reply #1 on: 10 July 2011, 16:09:02 »
Yes, you will need to remove them both to get easy access to the adjuster.
« Reply #2 on: 10 July 2011, 20:07:47 »
I tend to only remove one side - depends how good/bad your rachet 13mm spanner is.
blue_dream
  • Wellingborough
« Reply #3 on: 10 July 2011, 21:46:27 »
Hi
   No you don't need to take heatsheilds off, just need several extension bars and feed through from the rear propshaft bearing to the front, dead easy and alot quicker  :y
tidla
  • solihull
« Reply #4 on: 10 July 2011, 22:19:25 »
adust the shoes first??
2woody
  • Northumberland
« Reply #5 on: 11 July 2011, 09:19:23 »
absolutely. In all my time with Omegas, I've never adjusted the centre adjuster. Shoes always !
« Reply #6 on: 11 July 2011, 10:12:45 »
We tend to recommend loosening the cable, then doing the adjustments on the shoes, then readjust the cable. This ensures everything is correct :)
Page created in 0.027 seconds with 16 queries.
