Author Topic: heater bypass valve  (Read 1541 times)
shane1000
  • derby
  • studied nothing for 35yrs so now an expert on it
heater bypass valve
« on: 11 July 2011, 18:08:33 »
have just fitted new hbv but not sure if i've got it on right way round.... being a total dimwit i did'nt make note of which way round before removal .   does anyone know which way? is it vacuum pipe towards front or rear.?  i ran engine after fitting but temp. hit 100 .  got part from scrappy so not sure if its faulty or not.
Re: heater bypass valve
« Reply #1 on: 11 July 2011, 18:13:32 »
Small vac hose from pollen filter area goes to top of HBV. Main water hose from engine goes to the single outlet, top matrix hose going through bulkhead to top of the double outlet side, bottom matrix bulkhead hose to bottom double outlet side.
.............s/h HBV`s aren`t a good idea for the sake of 30 odd quid + the work involved changing the darn thing
« Last Edit: 11 July 2011, 18:14:19 by RobG »
shane1000
  • derby
« Reply #2 on: 11 July 2011, 18:19:14 »
thanks.  mrs. has gone to get ear muffs for her and plasters for me... see you in an hour. :P
« Reply #3 on: 11 July 2011, 18:21:06 »
20 minutes and no plasters on a 2.2 ;)
shane1000
  • derby
« Reply #4 on: 11 July 2011, 18:22:35 »
show off... :D :D :D
« Reply #5 on: 11 July 2011, 18:26:52 »
20 minutes and no grunt on a 2.2 ;)
Fixed that for ya. :y
« Reply #6 on: 11 July 2011, 18:36:52 »
20 minutes and no old fart named Albs on your shoulder on a 2.2 ;)
Likewise ;D
shane1000
  • derby
« Reply #7 on: 11 July 2011, 21:02:05 »
rob g your a star ;D ;D ;D  i had got the top and bottom bulkhead pipes the wrong way round.  mrs just happened to want to go shopping so that was the test drive. i was the only one in the car park smiling    thanks  :D :D
