Author Topic: 2002 Elite 3.2 self level rear shocks  (Read 1759 times)
Ant - Petrol Blue Thirty Two
  • St. Ives, Cornwall
    • 2002 Elite Saloon 3.2
« on: 09 July 2011, 14:51:56 »
Does anyone have experience of the above? Replaced the originals @ 69k (because one side leaked a watery liquid and left a pool under the rear wheel) but with non self level shocks at the advice of local vaux dealer.  Car thru rear  mudflaps, kept bottoming out so we replaced them with new GM self level again.  On all (or most) road deviations of a 'hole'/ 'ridge' kind, the rear end would give up a hollow slapping sound as if the rear wheels were just thrown into the holes without any spring or resistance causing a noisy 'hit' sound.  All rear end was thoroughly checked for bushes/play etc. and nothing came to light.  To prove/eliminate other possibles, we re-fitted the non self level shocks and the noise disappeared and returned to quiet and normal rear end suspension you would expect for 68k.  Under warranty, returned self level shocks to GM and fitted a brand new GM pair again and guess what, with the same 'slapping down noises are just as evident. I might add that the normal up and down smooth operation on the road deviations is perfect and the shocks do self level on ignition its just that they don't seem to perform on regular holes.  The original factory fitted that these were replacements for, never squeeked at all and i did wonder if the replacements spec was the same.  Vauxhall dealer suggested I fill the boot with some weight to see if that helped but even if it does, who wants to carry a bag of cement in the boot as old ford capri handling problems were solved by?  Can any one shed some light cos as you know, any noises you can't identify or cure just eat you away or drive you nuts with frustration!!!  Thanks in advance, Newcastle Ant
Varche
  • middle of Andalucia
    • Golf Estate
Re: 2002 Elite 3.2 self level rear shocks
« Reply #1 on: 09 July 2011, 15:37:58 »
The replacement shocks will be the same as original fitment. They are only made by VX/Opel.
Is this an issue with the rubbers/washer on the top of the shocker? The fact that it doesn't do it with non self levelling sort of eliminates trailing arm bushes and the like.
For your info(sorry if you already know) the Elites have softer springs fitted at the back to complement the shockers and their self levelling. Gives a "luxury" ride.  ;D
« Reply #2 on: 09 July 2011, 17:21:27 »
As Varche says, IIRC the bushes etc at the top come as a seperate fitting kit. Have theses been fitted to the new self leveling shockers?  :-/
ianu
  • Oxfordshire
    • XC90/Maserati QPV/CooperS
« Reply #3 on: 10 July 2011, 12:15:33 »
Hi Andy - I assume you mean these bits. Nearly caught me out when I replaced mine. I had to salvage the old ones - they took a bit of pursuading to get off..
..I can see why it'd make a difference too..
Cheers
Ian
« Reply #4 on: 10 July 2011, 18:12:50 »
thanks for the above guys, I'll take it up with my garage and see if the problem is to do with rubbers.  I'm amazed at the response knowledge and photos of the the exact area/parts you are referring to - well impressed!!!  thanks a lot - will come back with any results - might help others too
thanks again.
Newcastle Ant
« Reply #5 on: 10 July 2011, 18:27:53 »
Hi Andy - I assume you mean these bits.  .......
Yes  :y
ianu
  • Oxfordshire
« Reply #6 on: 10 July 2011, 22:21:17 »
Yes  :y
No problem - could I suggest adding this bit to the guide as it doesn't specifically mention these 2 parts (which is actually why I took the photos tbh).
When I changed mine - because they were 'stuck' on the old shock I assumed they were part of the component and also 'assumed' that the new ones didn't need them  :-? as the rubber bush sits quite snug directly on top of the shock. It wasn't until I took the other one off and the bits fell off straight away that I realised the error of my thinking. Luckily it is literally a 10 minute job to undo and refit correctly with the base plate and steel bush supporting the top rubber mount.
Cheers
Ian.
  • Auckland
    • Mazda MPV
« Reply #7 on: 10 July 2011, 22:37:33 »
I replaced the self levelling dampers on my Elite a few months back.
The new ones came with the washers, spacers and rubbers that Andy's photo shows but I had to reuse a rubber washer that fits under the top nut inside the boot.
hotel21
  • The Kingdom of Fife
« Reply #8 on: 11 July 2011, 13:22:19 »
When the car was ran with non self levellers was the compressor isolated?  If not then that could be non functioning. Fuse/rubber ducked motor.  ::)
« Reply #9 on: 12 July 2011, 08:03:01 »
thanks for that - yes the pump fires up on ignition and rubber pipe next to headlamp sucks air in for a few seconds, so presume level assist. is working - ant
Page created in 0.01 seconds with 14 queries.
