Author Topic: ABS Light ON  (Read 2271 times)
Boditza
  • Craiova, Romania
ABS Light ON
« on: 10 July 2011, 20:19:02 »
I know that on every page there is an ABS but none as far as i have searched seemed like mine(can't say i searched them all :P )
So my abs light came on for the first time yesterday as i was cruising at 100km/h. i stopped the car after 10km then started again but the light was still on for 3-400m then it went off. when i reached the cruising speed again the light came on again. and so on.. i the citi i never went over 60km/h and the light didn't came on. there is no certain high speed at wich it lights up because i went as far as 180km/h and it didn't came up.. so there is a certain mood that it has :). everything in the dash works. as a side note yesterday was the first day that the outside temp reached 38 degrees celsius.
Re: ABS Light ON
« Reply #1 on: 10 July 2011, 20:55:13 »
maybe a dodgy ABS sensor ......  :-/ :-/ or perhaps dirty reluctor rings that the sensors look at.  :-/ :-/
A proper code reader will be able to give yo a definite answer though.  :y
Boditza
  • Craiova, Romania
Re: ABS Light ON
« Reply #2 on: 11 July 2011, 06:09:43 »
i will try to get to a code reader but thats not free.. like your advices :P. the rear rings near the diff are clean because they were full of dirt 4-5 months ago and i cleaned them but the front ones i haven't cleaned
Boditza
  • Craiova, Romania
Re: ABS Light ON
« Reply #3 on: 11 July 2011, 20:50:19 »
on op com it showed rear right speed sensor no signal... wich one is it?? my car is LHD so is it the one on drivers side or the one on passenger side?
Chris_H
  • E London/Essex UK
    • Jag XF Portfolio S 3.0D
Re: ABS Light ON
« Reply #4 on: 11 July 2011, 20:57:14 »
Passenger side on an LHD.
First Vauxhall - PABX Cresta; Previous, previous Vauxhall - 3.0 12v Senator CD; Previous Vauxhall Omega Elite 3.0V6 Saloon Auto
Re: ABS Light ON
« Reply #5 on: 11 July 2011, 21:02:48 »
When ever a manual or TechII refers to left or right, it means if you are sat in the car, so it doesn't matter which side of the car the steering wheel is on.  :y  :y  :y
Re: ABS Light ON
« Reply #6 on: 11 July 2011, 21:16:46 »
Does to me mate  ;D ;D ;D ;)
Re: ABS Light ON
« Reply #7 on: 11 July 2011, 21:20:42 »
 ;D ;D
Boditza
  • Craiova, Romania
Re: ABS Light ON
« Reply #8 on: 12 July 2011, 08:53:02 »
me too :P.. i have a bad experience with steering rods left or right :P. so now whenever i go to a parts shop i tell the seller on drivers side or passenger side. this way f it makes a mistake its his fault not mine and he replaces the wrong part. better to be safe ;). is there any chance it could be fine and full of dirt? or it just needs replaceing?
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
Re: ABS Light ON
« Reply #9 on: 12 July 2011, 09:16:49 »
if you disconnect the sensor and check its resistance with an ohm meter against the other side,they should be the same :y
other rides
Boditza
  • Craiova, Romania
Re: ABS Light ON
« Reply #10 on: 12 July 2011, 11:08:49 »
so i'll check the left one first then the right one.. if they are the same they must be dirty right? there is a verry small leak from the diff where the right drive shaft enters and i supose that that is what is causing this.. will keep my fingers crossed
henryd
  • west cornwall
Re: ABS Light ON
« Reply #11 on: 12 July 2011, 11:21:26 »
just checked the specs and the tolerance is 500-3000 ohms but both sensors should be around the same amount
HTH :y
other rides
