Author Topic: Coolant Leak!  (Read 3465 times)
Kate
  • Cornwall
    • Drives people mad
Coolant Leak!
« on: 08 July 2011, 16:51:57 »
Hi. Can anyone help?
I've got a coolant leak.  It's running over these two pipes in the picture.  What should I do? I don't know where it's coming from!  Many thanks! :y :-*
  • Online Online
Re: Coolant Leak!
« Reply #1 on: 08 July 2011, 17:11:05 »
I can't really tell from your picture, but if it's behind the driver's side front wheel have you looked at the back of the engine on the driver's side? Heater by pass valve lives there & is often a cause of water loss. The valve is around £35 from Vauxhall & should take about an hour or so to fit.  :y  :y  :y
« Last Edit: 08 July 2011, 17:12:10 by Andy_B »
Kate
  • Cornwall
    • Drives people mad
Re: Coolant Leak!
« Reply #2 on: 08 July 2011, 17:12:02 »
It seems to leak sometimes but not others.  I can't understand why.
I don't want to take it to a garage without getting any advice in case I get ripped off.  I haven't been using it much and it's losing about 2 litres a day.
Any advice would be great as garages take advantage of women sometimes.
Kate
  • Cornwall
    • Drives people mad
Re: Coolant Leak!
« Reply #3 on: 08 July 2011, 17:13:12 »
Thanks.  Would a novice be able to fit one? :-*
  • Online Online
Re: Coolant Leak!
« Reply #4 on: 08 July 2011, 17:14:20 »
Altering the heater temp will have an effect on water loss.
Have a look here  :y
http://www.omegaowners.com/forum/YaBB.pl?num=1193594464
  • Online Online
Re: Coolant Leak!
« Reply #5 on: 08 July 2011, 17:15:28 »
Depends what tools you have available  ;)
You need a box of plasters too  :-?  ;)   ;)
Kate
  • Cornwall
    • Drives people mad
Re: Coolant Leak!
« Reply #6 on: 08 July 2011, 17:29:14 »
Thanks very much.  Is there any way to confirm that the HBV is leaking? :y
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
Re: Coolant Leak!
« Reply #7 on: 08 July 2011, 17:34:28 »
Scuttle off and run the engine moving the temp regularly.  If you get the part pop around and ill swap it over in about 20 mins for a couple of bottles of waggle dance.
Kate
  • Cornwall
    • Drives people mad
Re: Coolant Leak!
« Reply #8 on: 08 July 2011, 17:58:00 »
Thanks! Where abouts in Hampshire are you? :y :-*
Kate
  • Cornwall
    • Drives people mad
Re: Coolant Leak!
« Reply #9 on: 10 July 2011, 12:38:35 »
Is there anyone in the West London area that would have at look at my poorly mig? I'll bring it to you! :y :-*
Kate
  • Cornwall
    • Drives people mad
Re: Coolant Leak!
« Reply #10 on: 10 July 2011, 17:52:51 »
Would an alcohol bribe help? ;D ;D ;D
  • Online Online
Re: Coolant Leak!
« Reply #11 on: 10 July 2011, 18:30:47 »
I'm sure Guffers will get back to you when he's finished rebuilding his engine.  ;)
Kate
  • Cornwall
    • Drives people mad
Re: Coolant Leak!
« Reply #12 on: 10 July 2011, 20:25:28 »
It's a good job mig engines are nice and simple then! ;D
duggs
  • Felixstowe
    • BMW 3.0 Sport
Re: Coolant Leak!
« Reply #13 on: 10 July 2011, 20:53:00 »
Assuming that's yer picture Kate, I'm amazed fellow Miggers aren't queuing up to help !
Kate
  • Cornwall
    • Drives people mad
Re: Coolant Leak!
« Reply #14 on: 10 July 2011, 21:33:00 »
Well I look more like Jo Brand in reality!  I've met several of the moderators and I think they've spread the word.
No wonder it's so hard for me to get help! ;D ;D ;D
Being a tactless old cow doesn't help either! ;D ;D ;D
Page created in 0.027 seconds with 16 queries.
