Author Topic: Re: wont tick over  (Read 903 times)
Re: wont tick over
« on: 16 July 2011, 23:13:10 »
Genuine sensor ? Fitted with wiring routed away from heat of exhaust ?
Re: wont tick over
« Reply #1 on: 16 July 2011, 23:32:11 »
Any codes with the paperclip :question
Re: wont tick over
« Reply #2 on: 16 July 2011, 23:59:29 »
19 should clear within 20 or so clean starts. It is possible that the new sensor is a dud. I had it happen once.
Easy way to tell if MAF is at fault - unplug it. The car should run Ok, but not as pokey as normal, as it reverts to a standard/default setting.
Worth checking the plug at the top of the sensor is pushed fully home ?
Re: wont tick over
« Reply #3 on: 17 July 2011, 01:30:02 »
Unplug the MAF and se if it makes any difference. ;)
