Author Topic: Broken stud....  (Read 1478 times)
HockeyDave55
  • Milton Keynes
    • 2000my 3.0 police special
Broken stud....
« on: 16 July 2011, 11:34:11 »
Hi,
While taking my exhaust off to get the gearbox out, I broke a stud on the NS exhaust manifold  :-[.
Am I going to have to take it off the engine or is it do-able on the car?
amba
  • Medway towns
    • German V6
Re: Broken stud....
« Reply #1 on: 16 July 2011, 11:52:14 »
Assume you are refering to the tud that holds the exhaust downpipe to the manifold ?
If you have now got the exhaust out the way and can see the open end of the manifold is there stud still visible.If so it would be worth trying a "Irwin stud extractor socket" they grip the broken stud with rollers and with any luck should get it out.
If no stud is visible and you are able to get a drill with a colbat bit and get a hole into it could then try an stud extractor by using the reverse thread on it.
If you have the resources some heat on it will help alot as will expand the metal.
All tools are available from Machine Mart
£22.49ex. VAT
£26.99inc.VATPRICE CUT!SAVE OVER £5Was £32.34 inc.VATproduct: 040215462
Laser 4462 Stud Remover Set - 5 Piece
Stud extractor set in short series for tight, restricted areas. Complete with ratchet spanner.
More info
Boa 'Grabit' Bolt & Screw Remover
A useful addition to any tool kit; a combined bolt & screw remover that fits in any variable speed drill with a 10 or 13mm chuck. The 'Grabit' easily removes damaged, broken or embedded fasteners from wood, metal or plastic. It’s the worlds first all in one screw & bolt extractor
HockeyDave55
  • Milton Keynes
Re: Broken stud....
« Reply #2 on: 16 July 2011, 18:09:50 »
Ok, the rain stopped so I went out to get the clutch off.
While I was under there, I had a look at the stud and there's about 10mm on there. I plastered it with WD40 but it looks more rusty than a rusty thing...... Oh boy!
I don't have anything that'll get much heat into it.
I work at Nissan tech centre so I'll have a chat with the guys in engines on Monday......
BTW, when I got the clutch out, the straps on the pressure plate were all broken!! Never seen that before???
Osprey
  • Redhill, Surrey
  • Drink up. The world's about to end.
    • 01 2.6 Elite saloon
Re: Broken stud....
« Reply #3 on: 16 July 2011, 21:50:06 »
You stand a much better chance with PlusGas, IMHO.
I feel like a military academy. Bits of me keep passing out.
Broomies Mate
  • Bristol, UK
    • Stuff!
Re: Broken stud....
« Reply #4 on: 16 July 2011, 22:20:58 »
This is the point where opinion is actually fact!  ;D
PlusGas is infinitely better than WD40 for 'hardcore' jobs.
WD40 is good for the more domestic applications.  :y
sticka_v8_init
  • Reading
    • 2.5 V6 Tourer
Re: Broken stud....
« Reply #5 on: 16 July 2011, 22:30:24 »
Totally agree again, used Plusgas for years and it works 99% of the time. WD40 used for those squeaky bits and door locks ;)
Those are my principles, if you don't like them I have others.
HockeyDave55
  • Milton Keynes
Re: Broken stud....
« Reply #6 on: 17 July 2011, 16:12:20 »
Ok, ok.. I get the point.... Plus gas it is..... I'll look for some in the week.
Thanks guyS!  :y
« Last Edit: 17 July 2011, 16:12:55 by HockeyDave55 »
sticka_v8_init
  • Reading
    • 2.5 V6 Tourer
Re: Broken stud....
« Reply #7 on: 17 July 2011, 17:35:12 »
Thanks guyS!  :y
 ;D ;D ;D ;D
Don't try Hellfrauds fella, small outlets will have it... or here - http://www.directcarparts.co.uk/product/256/801/plus-gas-releasing-fluid-aerosol-200ml.html :y
