Author Topic: Headlight washer question  (Read 1196 times)
« on: 17 July 2011, 15:21:03 »
Just fitted them and it appears that when the washers are used the windscreen washers operate as normal, but the H/L washers give a quick blast for a couple of seconds and then stop.
Hopefully this is normal operation ?
Tia.
Oh, one more thing. So I dont break them trying - how do they adjust ? havent looked closely yet, but first impression is that it doesnt look as obvious as the screen washers.
« Last Edit: 17 July 2011, 15:34:54 by albitz »
Re: Headlight washer question
« Reply #1 on: 17 July 2011, 15:45:17 »
Tia.
Quite normal & correct. Screen & head lamps are fed from different pumps.
The washers are a ball in a socket so I suppose will adjust, but haven't need to so haven't tried.  :-/
« Reply #2 on: 17 July 2011, 15:53:59 »
Tia.
Two options............traditional pin in jet hole method, or small flat blade in the slots by jet hole
« Reply #3 on: 17 July 2011, 16:39:52 »
Thanks chaps. :y :)
tango
  • brum
« Reply #4 on: 17 July 2011, 17:04:24 »
its a good good job they run for a short while
they tend to use a lot of washer fluid
« Reply #5 on: 17 July 2011, 17:06:31 »
I wondered if it was worth all the effort for a couple of little short squirts. :-/
Im sure Ive heard that phrase somewhere before. :-/
 :D ;D ;D
« Reply #6 on: 17 July 2011, 17:09:26 »
Job all done now (in between torrential downpours) - another little upgrade finished. Im wet but feeling satisfied.
I m sure Ive heard that phrase somwhere before. :-/
Then again, maybe not. :D ;D
ajr3773
  • Northumberland
    • 3.0Ltr Auto Elite
« Reply #7 on: 17 July 2011, 18:15:40 »
Do the headlight washers on the mig only work when the headlights are on or do they work all the time? I remember owning a BMW and they only worked every 7 pulls of the washer / wiper stalk when the lights were on.
« Reply #8 on: 17 July 2011, 19:08:05 »
Yep
