Author Topic: Headlights  (Read 1737 times)
REvil71
  • Wales
    • 3.2 Elite Saloon
Headlights
« on: 29 June 2011, 20:09:47 »
Hi
My drivers side headlight -zeon - is slightly lower than the passenger side. when i start the car up the display says there is a problem. would the fault be inside the fitting or elsewhere. if anyone can supply any details or pics of headlight that would be great. 8-)
Mr Gav
  • Leeds
    • Nissan 370z GT Edition
Re: Headlights
« Reply #1 on: 30 June 2011, 21:48:33 »
I think this is what you`re looking for  ;)
Headlight adjusters
I`ve just done one of mine for the MOT and I`ll do the other this weekend.
If you take off the cover above each light and reach down to the sidelight/main beam bulb rubber cover and and press forwards the lens will move if the adjusters are broken.
It could also be the servo motor not levelling up the lens, you can hear these when you turn on the ignition.
Re: Headlights
« Reply #2 on: 30 June 2011, 21:52:47 »
Headlight adjusters
I doubt that the ally adjusters would help here, the HID auto levellers would have no idea if the adjuster is broken so won't know to display the fault. This problem could very well be the motor for that headlight in that one light is moving & the other isn't.
Other fault areas are obviously the sensors front & back on the nearside suspension.
Re: Headlights
« Reply #3 on: 01 July 2011, 02:00:37 »
Hi
It would help if you said if you posted the error message displayed!
Assume you have HIDs - xenon lights.
As Andy says probably dodgy servo motor behind light unit.
REvil71
  • Wales
    • 3.2 Elite Saloon
Re: Headlights
« Reply #4 on: 03 July 2011, 17:03:27 »
just managed to reach behind lights. the fitting is so loose. rocking side to side, up and down. thinking someone done a bodge sometime. will have to remove headlight and investigate.
REvil71
  • Wales
    • 3.2 Elite Saloon
Re: Headlights
« Reply #5 on: 05 July 2011, 20:22:30 »
hey hey hey, its the adjusters, surprise surprise. broken off so headlight just hanging there no direction. have sourced a special supperglue with an activator which reckons it can bond anything. will try wednesday. heres hoping. 8-)
Re: Headlights
« Reply #6 on: 05 July 2011, 20:24:30 »
but as per my reply above, knackered adjusters won't put the warning message up.  ;)
The plastic adjusters have a waxy feel to them but here's hoping your super duper glue is up to the task in hand - Araldite isn't  ::)
« Last Edit: 05 July 2011, 20:26:10 by Andy_B »
REvil71
  • Wales
    • 3.2 Elite Saloon
Re: Headlights
« Reply #7 on: 07 July 2011, 17:52:58 »
Just managed to put all parts for the headlight back together and so far ... glue holding fine. tested lights and at moment haven't had the warning come up. will try night driving later and see how it performs. :D
REvil71
  • Wales
    • 3.2 Elite Saloon
Re: Headlights
« Reply #8 on: 17 July 2011, 19:17:13 »
Headlight fine but the problem was with the adjuster arm that feeds both headlights. Still, fixed and mot-ed now. good for another 12months
Nice to hear the tester say this is such a good car considering the age of it. ;)
