Author Topic: Transmission fluid  (Read 1296 times)
danzigfan
  • Jesenice, Slovenia
    • Omega 2.5V6, 3.0V6
Transmission fluid
« on: 17 July 2011, 19:57:29 »
I would like to change it because it probably wasn't changed at all and car has 220.000 km done. Which oil/ what wiscosity should it be? It's 5-speed manual,  thanks
Re: Transmission fluid
« Reply #1 on: 17 July 2011, 21:13:15 »
There is a specific Vauxhall oil to be used in a manual gearbox, & although red like ATF is different.
danzigfan
« Reply #2 on: 17 July 2011, 21:20:53 »
Thanks I"ll try to find it. Does anyone know how many liters will go in?
« Reply #3 on: 17 July 2011, 21:31:01 »
according to Haynes manual 1.2 litres
The manual says that there were 3 different oil used over the years and that if there is any doubt of what's in there, you should drain all the oil and use the latest specification ie tha fitted to 1999 onward : Vx transmission oil 19 40 768
(are Opel numbers the same as Vauxhal?  :-/)
danzigfan
« Reply #4 on: 17 July 2011, 23:56:20 »
I don't know about that, only went to stealers once, just to find out why "stealers"...Thanks
danzigfan
« Reply #5 on: 18 July 2011, 00:08:38 »
It's fuchs titan syntofluid 75w-80 if I'm right. Will search.for it tomorrow, thanks
