Author Topic: Part Numbers Advice - High Pressure Air Con Valve  (Read 1885 times)
ajr3773
  • Northumberland
    • 3.0Ltr Auto Elite
« on: 20 July 2011, 19:31:27 »
Anybody know how to get this off. Ive tried a 15mm & 16mm deep socket and neither fit. Nor does a spanner.
Looking at resorting to a pair of mole grips but this valve looks like its got 8 sides to it.
Is it a specialist socket or not.
Am i right in assuming id need to put a 17mm spanner on the hex on the pipe whilst turning the valve.
« Last Edit: 21 July 2011, 18:53:27 by ajr3773 »
Re: High Pressure Air Con Valve
« Reply #1 on: 20 July 2011, 21:42:57 »
A normal 15mm socket for me with, as you suggest, a 17mm on the fitting below to support the pipework. It's just not a very well defined hexagon due to the minimum diameter ally bar having been used to produce a 15mm across the flats hex.  :y
ajr3773
  • Northumberland
    • 3.0Ltr Auto Elite
« Reply #2 on: 21 July 2011, 18:43:22 »
Having looked at other threads ive contacted 2 separate Vauxhall dealerships today in an attempt to order this part but they have both told me that part number 52458177 does not show up and they have gone on to inform me that the only valve listed for my car is 3041827.
Can anyone on the forum confirm this and does this include the valve cap and the seal?
tidla
  • solihull
Re: Part Numbers Advice - High Pressure Air Con Valve
« Reply #3 on: 21 July 2011, 19:37:22 »
just get the air con bloke to change it as he has to gas it up anyway, they usually got them on the van.
ajr3773
  • Northumberland
    • 3.0Ltr Auto Elite
« Reply #4 on: 21 July 2011, 19:43:12 »
Air con bloke can't replace it as it is a different valve to the schrader types usually used on air con.
tidla
  • solihull
« Reply #5 on: 21 July 2011, 22:26:31 »
if he is filling your aircon system he must have come across them before...
« Reply #6 on: 21 July 2011, 22:59:44 »
Can you find the picture of the scan I posted about this recently? print it off & show them that it does exist, or just phone andyc  :y :y :y
Show your air/con expert these pictures ......
Your 15mm socket might need a tap to make it go on the valve, it is a snug fit.  ;)
« Reply #7 on: 21 July 2011, 23:00:59 »
It's the same valve on an Astra G if that's any use  :-/ :-/ :-/
andyc
  • Norfolk
« Reply #8 on: 22 July 2011, 09:17:37 »
52458177 is still available from GM and the OP has a PM
Andy
Thetford. Norfolk
« Reply #9 on: 22 July 2011, 09:38:57 »
Comes with the green Viton seal, but no cap. (Caps come from your local friendly scrap yard .......... apparently  ::))
ajr3773
  • Northumberland
    • 3.0Ltr Auto Elite
« Reply #10 on: 22 July 2011, 11:20:39 »
Why on earth can no other Vx dealership find it then.
Surely they all use the same bloody system.
Cheers Andyb & Andyc
