Author Topic: Diffs...  (Read 2029 times)
GmasterT
  • Cambridge
  • does that drifting thing...
Diffs...
« on: 11 July 2011, 11:07:57 »
Are they all much the same? IE will a 2.0 one fit on a v6 etc?
serek
  • huntingdon
    • 3.2 mv6
Re: Diffs...
« Reply #1 on: 11 July 2011, 11:24:05 »
front flange its different on 2.0 cars other mounting its same
Re: Diffs...
« Reply #2 on: 11 July 2011, 11:26:13 »
I believe they are all the same externally (others may know better) but there are quite a few different ratios. Probably worth findng out about the different ratios, so you can locate one which best suits your needs. :y
The prefacelift ratios will be in the Haynes book of 'dangle berries'.If you dont have a haynes book, let me know and I can give you the info from it. ;)
Edit. Smartarse RobG knew better. :D ::) ;D
« Last Edit: 11 July 2011, 11:27:18 by albitz »
GmasterT
  • Cambridge
Re: Diffs...
« Reply #3 on: 11 July 2011, 11:38:20 »
Is that an easy change?
 :y Well, ideally want the same ratio as on my current LSD I suppose, whatever that may be?! Dont fancy locking that one out as its worth half the car  ;D
GmasterT
  • Cambridge
Re: Diffs...
« Reply #4 on: 23 July 2011, 22:19:08 »
Right, bumping this back up.
Fitted a 3.0 diff (thanks Serek) but its too long. Longer than the previous one (LSD) so need something shorter (and this week  ::)  :D) Serek has advised that a 2.2 or 2.6 auto one is the shortest?
Albs, may I ask for the ratio info you have please? I cant find my haynes  :y
Re: Diffs...
« Reply #5 on: 23 July 2011, 22:23:33 »
Im at work until the morning, but I can have look then. :y
Twiglet should have a 2.6 diff. I think his breaker is an auto, but Im not sure tbh.Best to check. :y
2woody
  • Northumberland
Re: Diffs...
« Reply #6 on: 23 July 2011, 22:27:51 »
I have 4.2 diffs available both LSD and "open"
Matchless
  • Nottingham
    • A white van
Re: Diffs...
« Reply #7 on: 23 July 2011, 22:28:02 »
3.0 diff is likely to be a 3.7:1, 2.5 manuals generally have 3.9:1.
If you want something shorter you could go for one from a 2.5 auto, 4.2:1, I think this was also used by the 4 pots.
I cant see why the 4 pots would have have a different drive flange, I thought all versions used the same rear half prop shaft, only the front bit changing between auto / manual
2woody
  • Northumberland
Re: Diffs...
« Reply #8 on: 23 July 2011, 22:34:43 »
no, the 4-pots have a smaller pcd on the donut bolts.
I'll measure one tomorrow ( I'm having a diff sort-out day ! ), it may be that the 4-pot is actually a smaller crownwheel (as per Omega A 4-pots)
serek
  • huntingdon
    • 3.2 mv6
Re: Diffs...
« Reply #9 on: 23 July 2011, 22:40:24 »
its same pcb on donut bolts , but I found place where  you bolt in bracket to diff its 2 different size of bolts on V6 cars
serek
  • huntingdon
    • 3.2 mv6
Re: Diffs...
« Reply #10 on: 23 July 2011, 22:43:18 »
I go to see mr Twiglet on monday so if you agree price I can pick up for you :y
GmasterT
  • Cambridge
Re: Diffs...
« Reply #11 on: 23 July 2011, 23:31:24 »
Youre a legend mate! I have pm'd him  :y
Any news on that induction box? :D
« Last Edit: 23 July 2011, 23:32:12 by GmasterT »
