Author Topic: fuel pipe  (Read 1158 times)
manolo
fuel pipe
« on: 23 July 2011, 20:10:13 »
when I  removed fuel pipes from plenum (2.6v6) one was dry and other have fuel in it
is it normal?
why one of it was dry?
« Last Edit: 23 July 2011, 20:13:00 by manolo »
Bionic
  • Leicester
  • Why drive anything else?
    • 1999 F/L 3.0 Elite saloon
Re: fuel pipe
« Reply #1 on: 24 July 2011, 05:38:07 »
One is a flow from the tank and the other is the return, probably because the electric fuel pump runs continously as soon as the ignition is on.  Mine has arrows on the label going in each direction.:y
tango
  • brum
Re: fuel pipe
« Reply #2 on: 24 July 2011, 07:14:14 »
the return pipe should be dry
have you got any problems with car
manolo
Re: fuel pipe
« Reply #3 on: 24 July 2011, 10:10:00 »
No, I was just replace spar plugs and I had to disassemble fuel pipes...
also heared vacum aspirate sound caused by broken O ring on plastik on top of plenum
« Last Edit: 24 July 2011, 10:32:04 by manolo »
