Author Topic: how to remove ignition lock cylinder without key  (Read 1326 times)
AjOmega
  • Cali
« on: 23 July 2011, 20:32:06 »
hey im trying to remove an igntion lock cylinder on a cadillac catera but i dont have a key and im not trying to ruin the piece. I tried putting the alley key in the small hole but it still didnt come out any suggestions?
Re: how to remove ignition lock cylinder without key
« Reply #1 on: 23 July 2011, 21:15:52 »
You need a key, that the point of needing a key in the lock  ;) The only way to remove it without a key is to drill down the centre (center  ::)) and then remove the remnants of the tumblers.  :y :y
AjOmega
  • Cali
« Reply #2 on: 23 July 2011, 21:26:32 »
Alright thanks :)
« Reply #3 on: 24 July 2011, 20:55:23 »
Or a slide hammer with a hardened screw in the end ;) But either of these methods will destroy the barrel ;)
tango
  • brum
« Reply #4 on: 25 July 2011, 01:02:40 »
if you aint got the key
easiest way would be to break it off
AjOmega
  • Cali
« Reply #5 on: 25 July 2011, 16:08:45 »
yea ima try breaking it off cuz the car is at a pull yard so they wont care then ill just go to a locksmith to get a key for it.
