Author Topic: ecu abs/tc lights on  (Read 1300 times)
smurfdjman
  • Inchinnan,Renfrew,Scotland
« on: 25 July 2011, 17:25:24 »
abs/tc lights on
Re: ecu abs/tc lights on
« Reply #1 on: 25 July 2011, 17:28:02 »
Speedo stops working ??
Steering gets heavy ??
all works again after 10-15 minutes then fails again 30 minutes later ??
ABS ECU needs repairing
BBA-Reman did a good job on mine .. :)
« Reply #2 on: 25 July 2011, 19:09:03 »
Yep - afraid abs ecu breaked mate  :(
Fiddly job to replace - think there's a howto on here - if not do a search as a number of members have changed them (me included) with either repaired ones or used ones.
bigdumper3
  • preston
    • omega 2.6 v6
« Reply #3 on: 25 July 2011, 22:58:01 »
mines is the same, can you buy a used one seperate from abs pump
rbrueford
« Reply #4 on: 25 July 2011, 23:03:38 »
Strangely, mine did that on the way home today. Just pulling up at a set of lights, nowt heavy or such and tc/abs light came on. Got to petrol station, filled up, switched back on and they had gone out!
« Reply #5 on: 26 July 2011, 02:42:06 »
You'll see them on again!!!  And eventually they'll be on all the time   :(
« Last Edit: 26 July 2011, 02:42:24 by dbug »
Page created in 0.031 seconds with 16 queries.
