Author Topic: Changing oil in automatic gearbox (3.2 V6)  (Read 4620 times)
zYx
  • Kent
  • Member of Mayday
    • Black 3.2
    • Grischke Solutions
Re: Changing oil in automatic gearbox (3.2 V6)
« Reply #15 on: 17 May 2011, 18:42:22 »
Right, as far as I'm concerned there is two ways for changing oil. Static and dynamic..
The guy from vauxhall garage says that they would only be able to change max 60% of oil which means static way to me, and is unacceptable. The guy meant to call me back with the price and guess what - he never called... so I might just do it myself.
Anybody knows a good online store with gaskets and filters? :) and oil?
    • 530D M Sport, 330i Coupe
« Reply #16 on: 17 May 2011, 18:59:14 »
Yep, that's right because you cannot easily get the fluid out of the torque convertor.
zYx
  • Kent
  • Member of Mayday
    • Black 3.2
« Reply #17 on: 17 May 2011, 19:06:28 »
Ok, so according to this catalogue, what part would I need?
Gaskets, filter, oil. Anything else?
I have another question though. My box makes a little rattling noise when put on R or D. Not sure whether it is the gearbox or something totally different and not related to the box, but it's worrying me :(
« Reply #18 on: 17 May 2011, 19:12:26 »
Latex gloves, plastic bag for head, shampoo, plastic sheet to lay under car, the Mrs' favourite washing bowl etc etc
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #19 on: 17 May 2011, 19:21:17 »
it may be worth checking that the torque converter is securely bolted to the drive plate while you are underneath doing the oil,also look closely at the driveplate as they can crack around the fixing bolts
other rides
zYx
  • Kent
  • Member of Mayday
    • Black 3.2
« Reply #20 on: 17 May 2011, 19:23:27 »
:P
btw I contacted jpat for prices...
zYx
  • Kent
  • Member of Mayday
    • Black 3.2
« Reply #21 on: 31 July 2011, 19:06:17 »
Right, I have the parts now (£55 delivered), all I need is oil. Can you recommend good online store?
Is this oil any good? http://uleak.it/?5ds
« Last Edit: 31 July 2011, 19:09:32 by zYx »
« Reply #22 on: 31 July 2011, 19:46:14 »
heard not great reports on the Comma.
OOF reccommended fluid is Fuchs Titan 4000 from OPIE oils, or other supplier.
« Reply #23 on: 31 July 2011, 21:04:52 »
I used Comma, it's been there for the past few years with no ill effects & the car is mostly used for towing these days.  :y
Raymienets
  • Glasgow
    • 2.2 cd & 2.6 LPG
« Reply #24 on: 31 July 2011, 21:39:23 »
I had read a thread on here way back about syphoning pumps. Well I purchased one on ebay and had used that to drain all the gearbox oil out of the sump before removing. Cant send toy a pic of it as my son accidentely threw it out. When replacing the gearbox oil get litre bottles and go to your local DIY place and get a piece of tubing. Connect to your litre bottle and you will find you can refill it a lot easier and saves a lot of mess.
Something like this
http://www.ebay.co.uk/itm/SIPHON-SYPHON-PUMP-FLUID-OIL-LIQUID-TRANSFER-EXTRACTOR-/270752033588?pt=LH_DefaultDomain_3&hash=item3f0a142b34#ht_1240wt_911
« Last Edit: 31 July 2011, 22:03:21 by Raymienets »
« Reply #25 on: 31 July 2011, 21:44:00 »
..... and get a piece of tubing. Connect to your litre bottle and you will find you can refill it a lot easier and saves a lot of mess.
That's how I filed mine, but the bloody tube fell out of the gearbox & I ended up with oil over my drive.  ;)
Page created in 0.046 seconds with 16 queries.
