Author Topic: Project - battery charging  (Read 7880 times)
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
« on: 08 October 2006, 10:44:09 »
As it is extremely difficult to get into a facelift if the battery goes flat I have decided to embark on the following project.
Fix a 'caravan type' socket (which is reasonably waterproof) to the scuttle tray underneath the front of the vehicle.
Wire a positive lead (with an inline 1amp fuse) to the + terminal of the battery.
Wire a negative lead to a 0v earth.
Then using a 12v, .500 amp charger, with a 'caravan type' plug on the end, I can charge the battery without needing to get into the car.
I take your point Mark about the boot, but you cannot get into the boot on mine if the battery is flat.
Any feedback would be welcomed.
I like red cars
miked
  • North Yorkshire
Re: Project - battery charging
« Reply #1 on: 08 October 2006, 11:08:35 »
I have a facelift, why is it difficult to get into them if the battery is flat?
It seems like a lot of effort to go to, with a healty battery you shouldn't have any problems?
1 amp  :-?
Martin_1962
« Reply #2 on: 08 October 2006, 11:42:38 »
I need to see if my 12N or 12S has a direct route to battery, or at least just add a direct feed on a spare pin
Taxi_Driver
« Reply #3 on: 08 October 2006, 12:05:09 »
If the battery was dead flat, which it would need to be, not to operate the central locking......I would imagine a .5amp charger would take forever and a day to charge the battery.
Look at page 58 in your manual AA, in mine it tells how to open the drivers door in the event of a flat battery  ;)
« Reply #4 on: 08 October 2006, 14:45:35 »
:-?Put the key in the driver's door lock & turn it?  :-?  ;)
Martin_1962
« Reply #5 on: 08 October 2006, 17:03:37 »
Hard work for AA?
RonaldMcBurger
« Reply #6 on: 08 October 2006, 18:14:28 »
Sounds great! have you ordered a new alterbnator yet then? - to replace the one you will damage by charging the battery stuill connected to the alternator ? :o
Taxi_Driver
« Reply #7 on: 08 October 2006, 18:15:38 »
Hard work for AA?
It says basically that if the car has been deadlocked using the remote and car battery goes flat....then insert key turn clockwise and pass the point off resistance, then back to upright position and remove key......door will then open but the door lock button remains in the down position.
Think this works on prefacelifts too
« Reply #8 on: 08 October 2006, 20:07:33 »
Yes, a deadlocked car can still be opened with key - though it is scary due to amount of resistance, and feels like key is going to break first....
x25xe
  • Hayes, Middlesex
  • Avater removed due to size
« Reply #9 on: 08 October 2006, 20:30:43 »
Seems a good idea to me - BUT what Ronnie says is correct - you should never charge a battery with the alternator still connected.  You could always put a diode in line with the alternator output in order to prevent any back flow, but you would need a heafty one (+ 120AMP) which I doubt is even available.  You could also use a switch, one of those battery security switches would be ideal.
However, for all the hassle is it worth it?
What about one of those solar panel chargers - does anyone know who they get around the alternator problem?
Another answer is you could always fit a bigger battery meant for a deisel.  These have a higher AH rating which means they are better suited to periods of non use.
Hope this helps
« Reply #10 on: 08 October 2006, 20:30:57 »
The problem Auto Addict has is that due to the many short journeys he does the battery slowly loses its charge (the start current is not replaced adn its worse when cold).
The charger chosen is a trickle charger and is safe to connect to the battery when installed in the vehicle (its a controlled voltage units with smoothed output) adn will not damage any internals.
Sounds like a good idea AA....you might want to look at something smaller than a trailer hook-up though....
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #11 on: 08 October 2006, 20:36:36 »
I went to Maplins yesterday, didn't seem to have anything suitable that could be exposed to the elements.
Mark, the reason I thought of a trailer hook up is, many years ago, I used to tow a trailer and have lots of bits and pieces, and also, they are reasonably water proof.
RMcB, why would it damage the alternator?
I like red cars
Taxi_Driver
« Reply #12 on: 08 October 2006, 22:12:40 »
If AA's doing loads of short journeys and battery is suffering.....it sounds like to me a good idea to use the 0.5 amp trickle charger whenever he's parked up at home.....that way battery will stay happy and never flat enuf not to start the 2.2......i assume you either have a garage or can park your meega close enough to your house to run the mains cable  :)
Taxi_Driver
« Reply #13 on: 08 October 2006, 22:16:42 »
Or alternatively......just take the Omega out once a week and blat it down the motorway for 20 mins......enuf to recharge the battery.....opppss i forgot you dont go over 45mph.....so forget that silly suggestion  ::)
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #14 on: 09 October 2006, 06:34:40 »
The problem with batteries is mainly over the winter months, short journeys hammer a battery and it is never really fully charged.
Even long journeys, if you are sat in a lot of traffic jams (quite usual in todays type of motoring), with lights, heater etc. on you may never really fully charge a battery during the winter months.
How often do you check the condition of your battery with a meter?
Nearly everyone assumes because the car started in the morning, the battery is OK, then suddenly, one morning - nothing!
Even newish batteries can let you down over the winter months.
My philosophy is, prevention is better than cure.
I like red cars
Page created in 0.021 seconds with 16 queries.
