Author Topic: Front Suspension Bushes (Rear Polys?)  (Read 3731 times)
J.S.B.
  • Colchester, Essex
    • 2.5v6 Elite
« on: 05 August 2011, 17:38:33 »
Hi,
I've bought a set of PowerFlex Front Suspension and Antiroll bushes but when I looked at my arms I noticed the rear bush looks a bit tired on both sides, so I though I'd try and find replacement bushes for them too before starting work.
Can you get rear poly bushes? If so can anyone link them for me please?
Regards
Things to do: Air Con still leaking
Osprey
  • Redhill, Surrey
  • Drink up. The world's about to end.
    • 01 2.6 Elite saloon
Re: Front Suspension Bushes (Rear Polys?)
« Reply #1 on: 05 August 2011, 17:45:54 »
Rear bush polys are not available as far as I know.
I feel like a military academy. Bits of me keep passing out.
razzo
  • Crapital
    • 97 3.0 Elite
« Reply #2 on: 05 August 2011, 18:12:54 »
they are not available off the shelf, but it can be done
Mr Gav
  • Leeds
    • Nissan 370z GT Edition
« Reply #3 on: 05 August 2011, 18:35:59 »
Does anyone know which powerflex bush was used?
« Last Edit: 05 August 2011, 18:36:40 by Gavin_Chaney »
razzo
  • Crapital
    • 97 3.0 Elite
« Reply #4 on: 06 August 2011, 10:36:08 »
not made by powerflex, i made them up myself  :y
« Last Edit: 06 August 2011, 10:37:02 by razzo »
« Reply #5 on: 06 August 2011, 10:39:34 »
Think you may have found a gap in the market there Razzo.  :y
J.S.B.
  • Colchester, Essex
    • 2.5v6 Elite
« Reply #6 on: 06 August 2011, 11:40:29 »
Yeah  :y
How much for a pair of them?
Mr Gav
  • Leeds
« Reply #7 on: 06 August 2011, 18:51:50 »
Yeah  :y
I`d be interested too  :y
« Reply #8 on: 06 August 2011, 18:58:19 »
And me, and probably another 50 or so omega owners ;)
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #9 on: 06 August 2011, 22:16:35 »
Considering the movement that particular bush has to accomodate, surely it has to be a void bush, and not a solid one? Which is a pity, as a length of polyurethane and a sharp tool in the lathe would soon produce such a thing.
It's yet another instance of just good enough design; after all, Escorts suffer from exactly the same problem, although a new wishbone is only £15.
« Reply #10 on: 07 August 2011, 10:56:23 »
Can Polly be bought in a tube? Possibly in the relevant in side and outside diameters...?
Center spacer should be easy enough.
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
« Reply #11 on: 07 August 2011, 11:04:46 »
And me, I would delay fitting the new wishbones I was planning for this week if someone is going to make some......
razzo
  • Crapital
    • 97 3.0 Elite
« Reply #12 on: 07 August 2011, 11:12:21 »
its available in the right size off the shelf but it aint cheap, just need to cut them to length, drill the hole & get the tubes made up. Bar comes in 12 inch lengths so should get a few bushes out of one bar, if enough peeps are interested shouldn't cost too much per pair  :y
Gaffers
« Reply #13 on: 07 August 2011, 11:15:24 »
Count me in if it can be done soon.
« Reply #14 on: 07 August 2011, 11:56:07 »
I must say, I'd also be surprised if you can get enough flexibilty from a solid bush yet have it last well enough in that application. Happy to be proved wrong, though.
